Steering wheel problem. Need help asap
Old Jun 28, 2009 | 02:52 PM
94.V6.VROOM's Avatar
Default Steering wheel problem. Need help asap
so i have 94 v6. The steering wheel pulls to the bottom left. Is there a bushing or something that needs to be replaced? Thanks. Need this for inspection.
Old Jun 28, 2009 | 03:15 PM
Amazing!
Old Jun 28, 2009 | 03:32 PM
Originally Posted by z28pete
Amazing!
Hm?? That doent answer my question lol
Old Jun 28, 2009 | 05:35 PM
osduck5's Avatar
Are you talking about the physical steering wheel or something with the frontend causing the steering wheel to pull the vehicle left?
Old Jun 28, 2009 | 06:38 PM
The steerin wheel where it tilts. Like something in it may have snapped when pulling yourself into then car.
Old Jun 29, 2009 | 09:42 PM
osduck5's Avatar
According to the drawings in the camaro parts manual, there is a steering column guide that is mounted up under the dash and it should have two bolts that hold it to the dash frame. Look to see if it is broken or the bolts are missing that attach the guide to the column. Looks like you will have to remove the plastic lower dash cover to inspect this part of the column.
Old Jun 30, 2009 | 12:18 PM
Failed Devices's Avatar
Check for a broken sway bar and front wheel alignment. When I originally bought my Camaro, it had a broken swaybar in the left front which caused the car to veer left all the time.
Old Jun 30, 2009 | 12:22 PM
The O.P. is talking about the upper portion of the steering column, where the tilt wheel pivot point attaches to the lower column. Could be a snapped pivot pin, but you won't be sure until digging into it. Try googling for an exploded view of the steering column.
Old Jun 30, 2009 | 01:01 PM
osduck5's Avatar
Oops, I was thinking about the entire column. Guess that is what happens when one is reading when they should be sleeping.
bbar
Mar 29, 2011 11:00 AM
2000blkz28
May 25, 2009 04:02 AM
1979RS
70-81 V8 Tech
Feb 20, 2008 07:45 AM
1979RS
Jan 15, 2008 09:37 PM
