starting up problems
Old Aug 11, 2007 | 12:13 AM
953.4l's Avatar
Default starting up problems
i have a 95 3.4l..its been starting up rough usually taking three times to turn over. i needed a new egr valve and figured that might solve my problem if it were stuck open.. that may be why i was having problems.. changed it and it still takes 2-3 tries to start it, on occasion it will rev up to 2k rpms on its own..im at a loss.. can anyone help?
Old Aug 11, 2007 | 10:19 AM
Default RE: starting up problems
Check the fuel pressure as you go to start up. There may be an internal leak in the system, such as a leaky injector, bad pressure regulator, or bad fuel pump check valve, and the fuel pump has to prime the system to get the pressure up. You can also force the system to prime by turning the ignition key ON & OFF several times, about 2 seconds apart, without trying to start the car. Immediately after this, try to start the engine. If it starts on the first try, you now know that the system is leaking.
Old Aug 11, 2007 | 02:42 PM
libertyforall1776's Avatar
I have the exact same problem on my 95 3.4L -- let me know if you find the solution... I haven't spent much time on it yet...
Old Aug 11, 2007 | 11:03 PM
953.4l's Avatar
thanks pete..i tried the turning the ignition on and off thingand sure enough the car starts every time.. now i know to check all of those things and try to find the leak thanks for all your help. -ed
Old Aug 12, 2007 | 02:58 PM
Yes, I had the same result, but will try it a few more times to validate -- then the fun part of troubleshooting which is the specific issue and fixing...
Old Aug 15, 2007 | 05:52 PM
funnyha_ha's Avatar
I have a 94 3.4L it does the same thing
EasternStryker
Feb 28, 2010 09:57 AM
videojunkie1986
Jun 3, 2009 06:02 PM
justingarcia947
Oct 8, 2008 12:25 AM
KrazyHobo
Nov 20, 2007 07:48 PM
jdubs1813
Nov 8, 2007 01:42 PM
