starting problem...
Old 01-24-2011, 10:38 AM
tripwire1124's Avatar
Originally Posted by Massey
the click x 10 thing makes me think that the battery may be dead or dying. Have that looked at. The ground that would cause starting issues is in the engine bay not under the dash. There are only 2 grounds I know of under the dash and they are both behind the kick panels so you dont have to remove the whole dash to get to them.
As for your RAP there are 3 main things that cause that to not work, First is the door pin switches. In your car from the factory they were on the cowl down near the lower hinge, and it is an actual pin switch. If the pin switches are the cause then usually the interior lights stay on for 20 mins before sutting off when you stop the car.
Corrosion can cause shorts and thus cause the failure as well. Remove the BCM from the car and inspect and clean with a toothbrush (not a wire brush) and some electrical contact cleaner. Now the last and most common is the solder joints on the board itself. Check this link out for info on fixing it
https://camaroforums.com/forum/93-02-general-41/body-control-module-repair-52062/
Hope this helps.
Massey
very good information here thanks massey....but as far as the grounds go...there are two of them that are right behind the headlights...but i took those off and cleaned underneath them....even took off a lil paint so i was for sure it would be on metal...i will check into the RAP for sure as well...
biggin59
07-02-2010 12:22 PM
PressyP
07-31-2009 03:54 PM
Z28beast
82-92 V8 Tech
10-14-2008 09:37 PM
typeomang
04-13-2008 08:59 AM
Fishy Dave
10-09-2006 09:59 PM
Quick Reply: starting problem...
