Start-up problem must
Old Oct 20, 2011 | 04:00 PM
gta3214's Avatar
Default Start-up problem must
Hey, I have a 1998 Camaro v6 3.8L all stock. Since about 15k miles ago I have to give it gas on startup. I have to rev it at around 2k rpm for about 5 seconds then I let off and everythings runs fine(idles at 1k rpm). I'm just now takin the time to fix it, cause someone told me that can't be good with it being fuel injected. Any ideas to fix this? I'm trying to fix it quick because I need to sell it. Everything else runs great on the car I just thought that might not look too good when letting someone test drive it. Thanks!
Old Oct 20, 2011 | 06:43 PM
Try priming the fuel pump before attempting to start the engine. Turn the key ON & OFF several times before attempting to start the engine. Keep your foot off the gas pedal. If the engine now starts right up, it is a sign that the fuel pressure is not holding when the engine is off.
Old Oct 20, 2011 | 07:19 PM
What pete said but it could also be what we use to call a lazy IAC. YOu could try cleaning the IAC. Sometimes the get all googed up sometime they just need replaced.
Old Oct 21, 2011 | 08:20 PM
gta3214's Avatar
I just did that and it started without pressing the gas like you said(took about 5 times). What can I do to fix this? Would a new fuel filter fix it? Thanks guys
Old Oct 21, 2011 | 08:48 PM
It is always a good idea to change the fuel filter regularly, but it should have no relation to your problem. Check the fuel pressure with a gage to verify that the fuel system is actually losing pressure. If it is, then there are several possibilities:
The check valve in the fuel pump failed and the pump has to be replaced.
One or more injectors are leaking. (My want to try fuel injector cleaner)
Pressure regulator went bad and has to be replaced
Actual fuel leak
bamaland101
Jan 26, 2013 09:14 AM
fasttony350
Dec 2, 2012 06:22 PM
Zemis88
82-92 V8 Tech
Sep 4, 2011 01:37 PM
allenvan
Dec 31, 2006 07:28 PM
mitymouse
Mar 27, 2006 12:25 AM
