spark plug wire help
Alright i have a 1994 3.4l and i need to put new wires on it but the person who i bought the car from had the wrong kind of plugs on it they were too long and they barely stay on the spark plugs. so my question is how would i go about putting them on if i cant match the length of the wires since all of these wires are long?
ok i'm sorry im just freaking out..... the wires that are on there now are too long and they barely fit on the spark plugs. i want to replace the wires but i can't match up the lengths so how would i go about putting new wires on there
Length shouldn't have a problem with fit, unless they're too short. It's pretty simple to put on new wires. Just go to an auto parts store, ask for a plug wire set for your car. Since I think you mean the lengths are out of order, just put the new ones where they fit best. But do not mix up the wire location (coil to spark plug).
Yup. Take 1 wire off, find a wire in the new set that is a good length, and put it on. Then move to the next wire. You might have to switch them around once to get it right.As long as you don't mix the orders up, you'll do fine.
No problem, we're here to help. I'm not 100% familiar with the 3.4, but I would guess that the longest wire will go to the back. If it is too short or tight, then it doesn't go there.
