sounds bad when shifting into reverse
5 speed, 95,v6, manual, whenever i try to put it in reverse, it makes a gross gears grinding sound, only slightly when i jam it into reverse but if i try to slowly put it in, it sounds terrible, any sugestions?
and whenever i take corners extremely fast, the traction light comes on, how do i turn off traction control completely?
Yeah, it sometimes happens to me too, I dunno why either, I'm not touching the gas at all. Or sometimes it will be really hard to shift into reverse, I have to shift to 1st again and then abck the reverse a few times :'(
The grinding that you hear is due to the lack of syncros on our 1st gear and reverse. If you don't want it to grind, hold the clutch in for a short moment before shifting to reverse, or shift to another gear (usually i do 5th since its the closest) before shifting into reverse. As for it not shifting into gear, i usually just release and reapply the clutch and it works.
corinnemarie22
03-30-2010 12:02 PM
