So About the Spark Plugs..
Old Nov 15, 2010 | 02:09 AM
KillNThrill24's Avatar
Default So About the Spark Plugs..
v6.. v8.. doesnt seem to matter. in the 4th gens its almost IMPOSSIBLE to get to those little guys. i dont have a lift, nor a cherry picker. i have floor jacks and jackstands out the whazoo. with that being said, anybody know of a good way to change plugs and wires?
Old Nov 15, 2010 | 03:46 PM
You need to try harder, it can be done. Flex head ratchet, and Gear Wrench pass through sockets and driver are a big help.
Old Nov 15, 2010 | 03:52 PM
osduck5's Avatar
With stock manifolds, I find it easier to set the front up on jackstands and use a creeper to slide under it and attack them from the bottom, except for the 5.7L passenger side. They are a PITA no matter how you try.
Old Nov 15, 2010 | 08:35 PM
RFxCamaro's Avatar
3.8 is not to hard. I can get to all of them with just a 2" extension except for the 6th one. I need to go trough the bottom.
Old Nov 15, 2010 | 08:57 PM
BasicConcepts's Avatar
Technical User
3.4 is easy just a 2" extension for all plugs
Old Nov 15, 2010 | 11:34 PM
ya i was asking my dad and he thought maybe from the bottom too, but ill see how hard it is to get them from the top as well. im in a 3.8. thanks for the help!
Old Nov 16, 2010 | 12:43 AM
RFxCamaro's Avatar
also remove the heat shields
Old Nov 16, 2010 | 01:20 AM
Technical User
ohh i forgot about the heat shield get rid of that crap makes the day a whole lot easier
Old Nov 16, 2010 | 05:46 AM
evilkal's Avatar
I've never tried to change all my plugs from the top... It just doesn't work :P
Old Nov 16, 2010 | 04:30 PM
Massey's Avatar
3.4L you can get to them all from the top easy (easy being a relative term with a 4th gen)
LS1 you can get to all but #8 from the top. Drivers side pretty easy, pass side more difficult.
3.8L (older manifold design)Remove the exhaust heat shields for best results. Then only the ones that are hidden behind the manifolds need to be had from underneath. #3 and #4
3.8L (Newer manifolds) all should be accessable from the top
LT1 (^*&^&%&$^%$&*@@$!^$&#) Just leave any hard alcohol or firearms out of reach while attempting this job!
Massey
