siphon fuel
Old Mar 12, 2007 | 09:22 PM
girdnerg's Avatar
Default siphon fuel
Hi folks,
I did a search, but it came up empty.
I'm working on a friends 2002 Camaro v6. The fuel pump is dead.
My problem is that the fuel tank is full and I can't get any size hose down the filler neck to siphon out the fuel. I seem to be hitting a check ball or something.
What is the easiest way to empty the tank?
Thanks,
Rob
Old Mar 12, 2007 | 10:11 PM
bluovlh8er's Avatar
Default RE: siphon fuel
drill a hole but you will need a new tank lol.
Old Mar 13, 2007 | 10:03 PM
Fuel Tank Draining
TOOLS REQUIRED[*]J 42960-1 Fuel Tank Drain Hose[*]J 42960-2 Fuel Flapper Door Holder
[ul][/ul]CAUTION: Never drain or store fuel in an open container. Always use an approved fuel storage container in order to reduce the chance of fire or explosion.
NOTE: Do not run the fuel pump unless the fuel pump is submerged in fuel in order to prevent damage to the fuel pump.[*]Remove the fuel filler cap.[*]Install the J 42960-2 into the fuel fill pipe in order to hold the door open.[*]Insert the J 42960-1 into the fuel tank until the hose reaches the bottom of the fuel tank.[*]Use an air operated pump device in order to drain as much fuel through the fuel fill pipe as possible.
[ol][/ol]
[IMG]local://upfiles/1197/3E3E5DDED51E4008AEB52DB81CF857E2.gif[/IMG]
Old Mar 13, 2007 | 10:47 PM
SnooperSnort's Avatar
Reminds me of the days of stealing gas...............lol Oh what that was like
juice+
Jun 9, 2012 10:51 PM
A1bertmarkovski
82-92 V8 Tech
Jul 2, 2011 05:24 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
