Shudders when it kicks into passing gear.
Old Mar 9, 2010 | 04:07 AM
bryns81z28's Avatar
Default Shudders when it kicks into passing gear.
I just recently bought a 94 camaro with the 3.4V^. It seems to run fine other than a real bad shudder when it kicks down into the passing gear. I really dont know to describe it other than that. It runs smooth as soon as it goes back up a gear. I guess mainly on hard acceleration. Does anyone have any ideas?
Old Mar 9, 2010 | 08:53 AM
tv cable could be out of adjustment.
Old Mar 9, 2010 | 10:32 AM
Jonny Dubyah's Avatar
Thats why i have satellite..may get fuzzy during storms..but thats why god invented dvd's..how about a tune up? Checked plugs and wires?
Old Mar 9, 2010 | 11:04 AM
The 4L60E doesn't have a TV cable.
Is the shudder there based on a certain engine rpm no matter what gear it's in? Or does it do it only in a certain gear?
Old Mar 9, 2010 | 02:12 PM
dc14u2no's Avatar
might wanna check your trans mount.if busted it will shudder badly.if you can get underneath try to lift rear of tailshaft.another way to check is open hood and have a friend stand next to car.start engine and put in gear(forward) with foot FIRMLY planted on the brake.give it gas like you are trying to take off.if rear mount is broken your friend should see the engine trying to rock forward or the rear of engine/trans lifting.but dont make a habbit of it or you'll break engine mounts.best to get under car.
3.4putter
Jan 28, 2012 07:35 PM
Adam78
Jan 7, 2010 01:32 AM
Camaro's kick A$$
Mar 7, 2009 07:28 PM
1981TypeLt
Nov 3, 2008 04:22 PM
Andross
Jul 25, 2007 04:31 PM
