Shifting Problem
Old Jun 9, 2010 | 11:28 PM
NovaBrad's Avatar
Default Shifting Problem
I just got a '00 camaro with a 3.8.(Automatic) When i was merging onto the interstate i noticed that when i gave it gas and started to accelerate when it shifts from 3rd to 4th, it gets to about 6000 rpms it loses a little bit of power, and i let off the gas then it kicks into the next gear. Is there a problem that would make it do this?
Old Jun 9, 2010 | 11:33 PM
Failed Devices's Avatar
Sounds normal to me. It goes into the next gear when you left off the gas so you aren't winding on 3rd gear as you decelerate.
Old Jun 10, 2010 | 12:17 AM
NovaBrad's Avatar
Good news. Thanks
Old Jun 10, 2010 | 12:50 AM
shift point is around 5500 on mine and there is no hesitation. whens the last time the trany was serviced? also sounds like u need a tune up.
Old Jun 10, 2010 | 11:30 AM
On my 02 V6 it will get up to 6k RPM's if I am on the gas and not letting up.
Old Jun 10, 2010 | 12:47 PM
NovaBrad's Avatar
It shouldnt be in too bad of condition. the car just rolled over 50k miles
Old Jun 10, 2010 | 02:12 PM
BasicConcepts's Avatar
Technical User
id do a filter and fluid change itll cost like 50$ and make your trans run awesome
Old Jun 10, 2010 | 04:51 PM
you could save up and switch to synthetic trans fluid. sounds like its supposed to shift at 6k so you should not have to let up on the thottle for it to shift at that rpm. whens the last time its had new plugs. the hesitation could be worn plugs. have the car scanned for trouble codes, could get an idea if there is a issue in the tranny. or the car as far as that goes.
Triangle12
Feb 20, 2012 08:27 PM
bigworm
Jan 27, 2011 01:05 PM
JohnBoy
70-81 Transmission & Differential
Jan 29, 2010 12:44 AM
jasonmddx
May 25, 2007 08:13 PM
Tacos Z
Jan 9, 2007 06:56 PM
