RUNNING OUT OF IDEAS!!! Need HELP!
You said it! Some people complain about their key being able to slip right out, while other unfortunate people in this world don't even have a key to call their own!
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
Pull those plugs after you get it running rough. And look at them
In the exact order you pulled them
Out so you know what cylinder is causing the problem. If it's fouled out then you need to check the spark and make sure it's not weak. If sparks good then chances are that injector has a slight leak. If one of the 3 plugs is showing signs of being lean and the other 2 are fouled then that injector is most likely pluged up. If you want you can also have all injectors cleaned and flow tested.
For the record, the problem is none of those things you mentioned and (In my professional opinion) I believe you are incorrect about the Anti-theft system being the problem. As I said, when I start it, it either doesn't fire, or it runs really choppy. I can, however, (with a lot of patience) get it to crank and idle correctly if I play with it a bit. Once she starts and idles correctly...SHE's A BEAST! My final diagnosis and what I am going to replace this evening is the Ignition assembly. I will let you know how that song plays out....LOL.
I think you are going the wrong way with the ignition system most of the time ignition system issue are worse under load and at higher RPM, Not better at higher RPMs and bad at idle. Issues that clear themselfs out at higher RPM are almost always Fuel/air mixture issue. That goes back to any gas engine, injected or carb. Of couse with any complicated electronic odd failure do happen but your in that 1/2% fluke area.
I never said the Vat system was the problem. Infact I said it is not the problem. A diagnosis is when we do tests and the test shows a part fails. It would be more accurate to say your final guess, I have no clue what an ignition assembly is. Primary or secondary Ignition? Did you mean the control modual and coil packs? I was making the assumption that all routine maintenance was up to date. Plug wires are not old. That said with a good fuel pressure test 95% of the cars that come into the shop with this complaint it is either a injector or a IAC\dirty throttle body issue.
im confused you say in your professional opinion. If your a professional why are you asking us? and if your a professional why are you guessing becuase In my opinion means your guessing.
BTW....It was the anti-theft screwing up. I replaced the interior ignition on the steering column and had it re-keyed by the dealer. She's all better. Thanks for all the advice and, in a few circumstances...a good laugh!
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
