Rough idle
Old Jul 8, 2010 | 09:16 PM
97Maroman's Avatar
Default Rough idle
Hey guys I have a question. The camaro im gonna buy has a real bad idle when its sitting still but when you give it a lil gas it smoothes out. it doesnt back fire or miss and when you drive it it has all the power in the world. Well, the guy im getn it from scanned the cars computer and one of the codes came up Throttle position sensor and multiple cylinder misfire. It cant be wires crossed or timing off bc it has great power. But I read on the internet where the throttle position sensor is pre-adjusted and if its off it will cause the motor to run like crap. DO you guys think that's what the problem is I mean is idles so rough at a stand still it shakes the whole car
Old Jul 8, 2010 | 09:26 PM
osduck5's Avatar
I would be leaning more toward plugs, wires, or coil paks but I would get the code numbers and research a little deeper. The timing for these cars are set by the cam position sensor and crank sensor.
Old Jul 9, 2010 | 07:43 PM
97Maroman's Avatar
He's got new plugs and wires in it and has a new crank sensor in it. maybe coil packs or cam position sensor huh.. Any of you guys have any more ideas to what it could be send me an email @lilmisthing91@aol.com thats my wifes email Im gonna be outta town for the wknd and I can use her phone to get into her email so shoot me an email there. Any help is appreciated
Old Jul 9, 2010 | 08:30 PM
Rough idle is usually an indication of misfire, or too low an idle speed. Could be ignition, fuel, or a mechanical problem resulting in low compression. A scanner should indicate which cylinder is misfiring, and give you a starting point.
Old Jul 9, 2010 | 08:37 PM
osduck5's Avatar
I hear you but these wires can get into the manifolds really easy and burn holes in them if someone is not really careful. Wouldn't hurt to double check them.
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
husker_camaro95
Feb 16, 2011 07:38 AM
CJ51974
Jun 1, 2009 08:59 PM
foxtrot51
Jul 23, 2007 08:38 PM
BOSS ROC
Mar 9, 2006 01:17 AM
