Rear wheel slop
Rear wheel slop
Hello. First post. I have a lot of lateral movement in the rear end. Both wheels move in and out about an 1/8". I can push sidways on the car with wheels on the ground and get a lot of movement and clunking. I can really feel it when driving. The whole car seems to shift to the side on corners.Is this normal? I removed the pin, c-clip and one axle. I see no visble signs of wear or damage to axle or any parts. The bearing seems to be intact with little wear. Do the clips wear?
