Rear main seal
Old Jul 3, 2012 | 05:48 AM
Chevy101's Avatar
Ok if there are no hoses where does my car get the fresh air for the PCV system
Old Jul 3, 2012 | 06:42 AM
fbodyrs96's Avatar
throttle body
Old Jul 3, 2012 | 11:27 AM
Below is a video that explains how a PVC system should work. If you got it backwards and the crank case has pressure that would make a lot more sense. For you to have Vacuum that would mean your freash air inlet was plugged and your PVC system was pulling way too much vacuum.
As a motor wears it is very common for the blow by to over run the ventilation system and push oil into the PVC vavle and the freash air inlet. I am pretty sure your 3800 pulls freach air from the throttle body, this is already filtered air that does not require adding a seperate filter.
If the PCV valve was pulling a lot of air into the intake manifold the result would be high idle. When you take off your oil cap the idle should go up because you are allowing more air into the motor.
Old Jul 4, 2012 | 09:58 AM
Chevy101's Avatar
So the air is routed directly through the intake plenum?
Old Jul 4, 2012 | 12:47 PM
fbodyrs96's Avatar
Yes, theres a hole in the TB, that goes into the pcv hole and then back threw the plenum and then down threw the lower intake, pass side head to the valve cover area.
Old Jul 4, 2012 | 02:02 PM
Since your crankcase isn't venting properly, make sure all those passages aren't plugged. As well as the PCV valve which you might as well just replace.
Old Jul 4, 2012 | 03:59 PM
Chevy101's Avatar
Well I replaced the pcv valve cause it went bad
Old Jul 6, 2012 | 03:04 PM
Chevy101's Avatar
What would cause the pcv system to clog up?
Old Jul 6, 2012 | 03:39 PM
Oil gradually sludging up from natural ring blow-by can be one way. Or if the PCV valve was clogged, either this one or one previously. That could cause the vent side to build up with oil fumes and sludge due to poor crankcase ventilation.
Old Jul 7, 2012 | 07:02 PM
  #20
Chevy101's Avatar
Well what ever the issue is I loosened the oil cap and the car didn't make a sound
bd92rs
Dec 16, 2010 11:03 PM
94ttop
Aug 13, 2009 08:23 PM
sp9o3
Nov 29, 2007 07:27 PM
eas69
Sep 19, 2007 11:32 AM
94Red
Aug 29, 2007 10:02 AM
