Rear end info needed
Old Jan 16, 2011 | 01:07 AM
RFxCamaro's Avatar
Default Rear end info needed
So I've been wanting to swap rear ends for a while now. The thing is that I dont really know **** when it comes to rear ends. I know my engines and trannys but rear ends not so much. Im going to include a link to one i want to buy. Anything else i will need to buy? http://sacramento.craigslist.org/pts/2162624525.html
Old Jan 16, 2011 | 01:47 AM
Massey's Avatar
are you going to be swapping the whole thing or just the gears? If the gears only then you will need a matched set of ring and pinion, and if you dont have Posi now is the time to get a posi carrier and install that as well. If you are going entire housing then you need to know what type of ABS you have there are 2 types 3 and 4 channel. 3 channel has one sensor on the housing and 4 channel uses 2 sensors on the wheels. Then are you going to keep the GM rear or are you going to go to a Ford 8.8 or 9" They are alot stronger and have hundreds of ratios, and lots of parts to choose from. Then last but not least is brakes upgrade to disk if you have drums.
Massey
Old Jan 16, 2011 | 01:59 AM
RFxCamaro's Avatar
The rear in the link is the on I want. I have a v6 non posi or disk and want posi and disk
Old Jan 16, 2011 | 02:06 AM
Massey's Avatar
I cant view CL ads while at work so I was not able to check what you listed.
Massey
Old Jan 16, 2011 | 02:13 AM
BasicConcepts's Avatar
Technical User
from what ive heard that should bolt right up before you buy any used rear end you should take the cover off and check out whats going on inside youll want to change the oil too and a new gasket
Old Jan 16, 2011 | 02:28 AM
Massey's Avatar
^^ +1
Massey
Old Jan 16, 2011 | 06:26 AM
depends on if you can reinstall the spring cups easily. have you checked around at the local wrecking yards to see whats available?
quote (I have a late model camaro disc brake posi rear end,with rear sway bar still on it.
The spring cups have been removed for custom application.
I have leaf spring pads for it.Not welded on yet,to set up for a leaf spring conversion
200.00 call Dave *** *** ****
I have seen these sell for 450 or better I put it cheap in order to sell it quick there i nothing wrong with this rear axle
I was going to put it in my sub framed 57 pickup but decided to go anouther rout) end quote
Old Jan 16, 2011 | 07:00 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I would get one with spring cups on it, according to the ad they were cut off. Make sure to get a rear from a 6 spd car because they have 3.42s. I got the aluminum driveshaft and rear from a car for $300.
Old Jan 16, 2011 | 02:22 PM
Technical User
my local jyard wanted 975 for a 02 SS rear the only one around
Drache
Mar 29, 2011 02:28 AM
cadmanof50s
67-69 V8 Tech
Dec 24, 2010 02:40 PM
abcer
Nov 5, 2009 05:51 PM
blvfisc
May 16, 2007 06:00 PM
tall
Mar 6, 2007 05:31 PM
