REALLY getting tired of having this problem
Old Apr 21, 2010 | 09:07 AM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Default REALLY getting tired of having this problem
The day I got my car I've been getting that damn P0306 code. In February I had new spark plugs and wires put in along with a lot of other replacement parts. The code went away until a week ago. My bf took the plug out and saw it was pretty burnt up already. We were thinking maybe it was just a faulty plug and/or wire (the wire appeared to be fine). So I'm planning on getting MSD wires and the NGK plugs soon to replace them. BUT the other day I went to work and sat idling for about 5 minutes and the service engine soon light came back on and started blinking/flashing. So I shut the engine off and ran my scanner and it came up with the same code. So I just erased it. But the blinking is what has me scared. I have NO idea what is wrong. I know this is somewhat vague, but does anyone have any ideas of what could cause this cylinder to have issues? I don't know if it's the plug, the wire, the fuel injector, the intake gasket, or even worse, the cylinder itself. I just don't know and I'm not financially ready to do a top end rebuild yet. P0306 is the only code it's throwing and there aren't any other symptoms going on, just runs a little rougher when the code pops up and my mileage gets crappy. My bf thinks I also might have somewhat of a lifter knock (I think that's what he called it), I dunno if that would be related or not to my cylinder 6 problem. Any ideas/suggestions please?
Old Apr 21, 2010 | 04:41 PM
Have you replaced, or tried swapping your coils? I've chased a problem like that before. and it came down to the only thing left was the fuel injector. A couple tankfuls of gas additive didn't do crap, and a replacement injector made it worse (I found out the hard way not to mix & match the make of injectors). I finally popped the injector out and let it soak in carb cleaner for a couple of hours, swishing it around periodically. Put the injector back in and it ran like a champ.
Old Apr 21, 2010 | 09:41 PM
libertyforall1776's Avatar
As I recall the blinking means misfire.
Ya sure it's P0306 and not P0300? Alldata points ya to P0300 for diagnostics...
Did you remove those heat shields on each cylinder? I was told to do so by a GM Service Tech when troubleshooting similar issues -- apparently they cause some issues. Didn't seem to be the cause of my problem, but they're gone, and MSD wires have longer boots anyhow to offset from the engine which is great.
You don't have an aftermarket alarm system installed do ya?
Check your wire routing to ensure they are going in the proper locations per the factory. Check plugs, wires, coil packs, injectors...
Old Apr 21, 2010 | 09:59 PM
Document ID# 207566
1998 Chevrolet/Geo Camaro
DTC P0300 Engine Misfire Detected
Circuit Description
The PCM has the ability to detect a misfire by monitoring the 3X reference and camshaft position input signals from the Ignition Control Module. The PCM monitors crankshaft speed variations (reference period differences) to determine if a misfire is occurring. If 2% or more of all cylinder firing events are misfires, emission levels may exceed mandated standards. The PCM determines misfire level based on the number of misfire events monitored during a 200 engine revolution test sample. The PCM continuously tracks 16 consecutive 200 revolution test samples. If 11 or more misfires are detected during any 10 of the 16 samples, DTC P0300 will set. If the misfire is large enough to cause possible three-way catalytic converter damage, DTC P0300 may set during the first 200 revolution sample in which the misfire was detected. In the case of a catalyst damaging misfire, the MIL will flash to alert the vehicle operator of the potential of catalyst damage.
Conditions for Setting the DTC
* No TP sensor, MAP sensor, ECT sensor, CKP sensor, CMP sensor, VSS, or MAF sensor DTCs are set.
* Engine speed between 550 and 5800 RPM.
* System voltage between 9 and 16 volts.
* The ECT sensor indicates a temperature between -6°C (21°F) and 120°C (248°F).
* Throttle angle is steady.
* The PCM is detecting a crankshaft RPM variation indicating a misfire sufficient to cause three-way catalytic converter damage or emissions levels that exceed the mandated standard.
Action Taken When the DTC Sets
* If the misfire level is non-catalyst damaging, the PCM will illuminate the MIL during the second key cycle in which the DTC sets.
* If the misfire is severe enough to cause possible catalyst damage, the PCM will immediately flash the MIL while the misfire remains at catalyst damaging levels.
* The PCM will disable TCC operation.
* The PCM will store conditions which were present when the DTC set as Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC
* The PCM will turn the MIL OFF on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present.
* A history DTC P0300 will clear after 40 consecutive warm-up cycles have occurred without a fault.
* DTC P0300 can be cleared by using the scan tool Clear Information function or by disconnecting the PCM battery feed.
Diagnostic Aids
The scan tool provides information that can be useful in identifying the misfiring cylinder. If the DTC P0300 is currently stored as DTC status Failed Since Code Clear, the misfire history counters (Misfire History Cyl #1 - #6) will still contain a value that represents the level of misfire detected on each cylinder. The scan tool displayed misfire counter values (Misfire History Cyl. #1 through #6) can be useful in determining whether the misfire affects a single cylinder, a cylinder pair (cylinders that share an ignition coil - 1/4, 2/5, 3/6), or is random. If the largest amount of activity is isolated to a cylinder pair, check for the following conditions:
* Secondary Ignition Wires. Check the secondary wires associated with the affected cylinder pair for disconnected ignition wires or for excessive resistance. The wires should measure less than 30,000 ohms (30K ohms).
* Damaged Or Malfunctioning Ignition Coil. Check for cracks, carbon tracking or other damage. Also check coil secondary resistance. Secondary resistance should be between 5000 ohms and 8000 ohms (5K ohms and 8K ohms).
* Substitute a Known Good Coil. Switch ignition coils and retest. If the misfire follows the coil, replace the ignition coil.
If the misfire is random, check for the following conditions:
* Crankshaft Position System Variation. Refer to CKP System Variation Learn Procedure . The crankshaft position system variation compensating values are stored in the PCM non-volatile memory after a learn procedure has been performed. If the actual crankshaft position variation is not within the crankshaft position system variation compensating values stored in the PCM, DTC P0300 may set. The crankshaft position system variation learn procedure is required when any of the following service procedures have been performed:
o PCM replacement or reprogramming.
o Engine replacement.
o Crankshaft replacement.
o Crankshaft balancer replacement.
o Crankshaft position sensor replacement.
o Any engine repair(s) which disturbs crankshaft/harmonic balancer to crankshaft position sensor relationship.
* System Grounds. Ensure all connections are clean and properly tightened.
* Mass Air Flow sensor. A Mass Air Flow (MAF) sensor output that causes the PCM to sense a lower than normal air flow will cause a lean condition. Try operating the vehicle within the fail records conditions with the MAF sensor disconnected. If the lean or misfiring condition is not present with the MAF sensor disconnected, replace the MAF sensor.
* Loss of EBCM/EBTCM Serial Data. If the PCM stops receiving data from the EBCM/EBTCM, DTC P0300 can set due to a loss of rough road data. Check for stored ABS/TCS DTCs, especially DTCs related to a serial data malfunction. Refer to Diagnostic System Check .
* Air Induction System. Vacuum leaks that cause intake air to bypass the MAF sensor will cause a lean condition. Check for disconnected or damaged vacuum hoses, incorrectly installed or malfunctioning crankcase ventilation valve, or for vacuum leaks at the throttle body, EGR valve, and intake manifold mounting surfaces.
* Fuel Pressure. Perform a fuel system pressure test. A malfunctioning fuel pump, plugged filter, or malfunctioning fuel system pressure regulator will contribute to a lean condition. Refer to Fuel System Pressure Test .
* Fuel injector(s) Refer to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Between 10-35 Degrees C (50-95 Degrees F) . Refer to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Outside 10-35 Degrees C (50-95 Degrees F) .
* Contaminated Fuel. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
* EGR System. Check for leaking valve, adapter, or feed pipes which will contribute to a lean condition or excessive EGR flow.
* Extended Idle. Excessive open loop operation caused by extended idling or short trip driving may leave deposits on the heated oxygen sensors. The deposits cause oxygen sensors to respond slowly to exhaust oxygen content, affecting fuel control and causing a misfire to be indicated at idle. This condition is not permanent. To determine if this condition is causing the DTC P0300 to be set, review the freeze frame and fail records data for DTC P0300. If the DTC P0300 occurs at high engine speeds, the condition described above did not cause the DTC P0300 to set. If the DTC P0300 occurs at idle or very low engine speeds and at engine coolant temperatures less than 80°C (176°F), the condition described above is very likely the cause of the DTC P0300 being set. The deposits on the heated oxygen sensors can be eliminated by operating the vehicle fully warm at mass air flows above 15 gm/s.
Important
If the level of misfire was sufficient to cause possible catalyst damage (if the MIL was flashing), ensure that the DTC P0420 test is completed and passed after verifying the misfire repair.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
2.
A condition that sets a DTC other than P0300 may also cause a misfire. If any of the indicated DTCs are set with DTC P0300, diagnose and repair the other DTC before using the DTC P0300 table.
3.
The Misfire Current Cyl # display may normally display a small amount of activity (0 - 10 counts) but should not steadily increment during an entire 200 revolution test sample period.
4.
Depending on the cause of the misfire, the Misfire History Cyl # counter will display a very large number for the misfiring cylinder(s); values for the non-misfiring cylinders will be less than 1/2 as great as the misfiring cylinder(s). When investigating a misfire, always start with the components associated with the cylinder(s) that has the largest number of counts stored in the Misfire History Cyl # counter.
5.
Steps 5 through 12 check for conditions that can cause a random cylinder misfire.
13.
Steps 13 through 22 check for conditions that can cause a non-random or single cylinder misfire.
DTC P0300 - Engine Misfire Detected
Step
Action
Value(s)
Yes
No
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to the Powertrain On Board Diagnostic (OBD) System Check
Are any of the following DTCs also set?
DTC P1380 Misfire Detected - Rough Road Data Not Available
Go to the other DTC first
Go to Step 3
1. Start and idle the engine.
2. Review and record scan tool Freeze Frame data.
3. Operate the vehicle to duplicate the conditions present when the DTC was set (as defined by the Freeze Frame data).
4. Monitor the scan tool Misfire Current Cyl # display for each cylinder.
Is Misfire Current Cyl # display incrementing for any cylinder (indicating a misfire currently occurring)?
Go to Step 4
Go to Diagnostic Aids
View Misfire History Cyl # on the scan tool.
Does Misfire History Cyl # display a very large value for more than one cylinder?
Go to Step 5
Go to Step 13
1. Visually and physically inspect the vacuum hoses for splits, kinks, and improper connections. Refer to Emission Hose Routing Diagram .
2. If a problem is found, repair as necessary.
Was problem found?
Go to Step 25
Go to Step 6
1. Visually and physically inspect the PCV valve for improper installation and for damaged O-rings. Refer to Crankcase Ventilation System Inspection .
Was problem found?
Go to Step 25
Go to Step 7
1. Inspect the throttle body inlet screen for damage or for the presence of foreign objects that may partially block the air flow sample through the MAF sensor.
2. If a problem is found, repair as necessary. Refer to Throttle Body Assembly Replacement .
Was problem found?
Go to Step 25
Go to Step 8
1. Check fuel pressure. Refer to Fuel System Pressure Test .
Was problem found?
Go to Step 25
Go to Step 9
1. Check the fuel for excessive water, alcohol, or other contaminants. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
Was a problem found?
Go to Step 25
Go to Step 10
10
1. Visually and physically inspect the PCM injector grounds, power grounds and sensor grounds to ensure that they are clean, tight, and in their proper locations. Refer to Wiring Repairs .
2. If a problem is found, repair as necessary. Refer to Wiring Repairs .
Go to Step 25
Go to Step 11
11
1. Visually and physically inspect the following areas for vacuum leaks:
* Intake manifold.
* Injector O-rings.
* EGR adapter
* EGR valve.
* EGR feed pipes.
Go to Step 25
Go to Step 12
12
1. Remove the EGR valve and visually/physically inspect the valve to ensure that the pintle is not sticking partially open. Also, inspect the EGR valve pintle and seat for carbon deposits or burrs that may interfere with the pintle closing completely.
2. If a problem is found, repair as necessary. Refer to Exhaust Gas Recirculation (EGR) Valve Replacement .
Go to Step 25
Go to Step 13
13
1. Check for proper fuel injector operation. Refer to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Between 10-35 Degrees C (50-95 Degrees F) or Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Outside 10-35 Degrees C (50-95 Degrees F) .
2. If a problem is found, replace faulty injector(s) as necessary.
Go to Step 25
Go to Step 14
14
1. Visually and physically inspect the ignition wires associated with the cylinder(s) which were misfiring to ensure that they are not damaged and are connected to the proper cylinders at the coils and at the spark plugs.
2. If a problem is found, repair as necessary. Refer to On-Vehicle Service in Ignition System.
Go to Step 25
Go to Step 15
15
1. Install a J 26792 spark tester at the spark plug end of the ignition wire for the cylinder that is indicated by the Misfire Current Cyl # counters or Misfire History Cyl # counters as having the most severe misfire (largest number of counts).
2. Jumper the spark plug end of the companion cylinder ignition wire to engine ground. The companion cylinder is the cylinder that shares the same ignition coil (i.e., 1/4; 2/5; 3/6).
3. Crank the engine while observing the J 26792 spark tester. A crisp, blue spark should be observed.
Is adequate spark present?
Go to Step 20
Go to Step 16
16
1. Remove and visually/physically inspect the ignition wires associated with the cylinders that were indicated as misfiring. Ensure that the wires and boots are free of carbon tracking and the insulation is not damaged.
2. If a problem is found, replace malfunctioning ignition wire(s) as necessary. Refer to On-Vehicle Service in Ignition System.
Important
If carbon tracking or terminal discoloration is apparent at the ignition coil end of any of the ignition wires, replace the affected ignition wire and the associated ignition coil. Refer to Ignition Coil(s) Replacement .
Go to Step 25
Go to Step 17
17
1. Measure the resistance of the ignition wires associated with the cylinders that were indicated as misfiring.
2. Replace any ignition wire(s) that measure greater than the specified value. Refer to On-Vehicle Service in Ignition System.
30 K ohms (30,000 ohms)
Go to Step 25
Go to Step 18
18
1. Remove and visually/physically inspect the ignition coil(s) associated with the cylinders that were indicated as misfiring. Ensure that the coil(s) and coil towers are free of cracks and carbon tracking.
2. If a problem is found, replace damaged ignition coil(s) as necessary. Refer to Ignition Coil(s) Replacement .
Go to Step 25
Go to Step 19
19
1. Measure the ignition coil secondary resistance.
2. If resistance is not between the specified values, replace the faulty ignition coil(s) as necessary. Refer to Ignition Coil(s) Replacement .
Did any ignition coils require replacement?
5K-8K ohms
(5000-8000 ohms)
Go to Step 25
Go to Step 24
20
1. Remove the spark plugs from the cylinders that were indicated as misfiring.
2. Visually inspect the spark plug electrodes for excessive fouling. Refer to On-Vehicle Service in Ignition System.
Go to Base Engine Misfire Diagnosis in Engine General Information and Mechanical Diagnosis.
Go to Step 21
21
1. Visually inspect spark plug insulators for cracks, carbon tracking, or other damage. Also, check electrodes for incorrect gap. Refer to Spark Plug Visual Diagnosis in Ignition System.
2. If a problem is found, replace affected spark plug(s) as necessary.
Was problem found?
Go to Step 25
Go to Step 22
22
1. Check for an engine mechanical problem.
* Base engine problem. Refer to Base Engine Misfire Diagnosis in Engine General Information and Mechanical Diagnosis.
* Damaged accessory drive belt or pulley.
* Damaged driven accessory (generator, water pump, drive belt tensioner, etc).
* Loose or broken motor mount.
Go to Step 25
Go to Step 23
23
1. Check for a transmission TCC problem. Refer to Torque Converter Clutch (TCC) Diagnosis .
2. If a problem is found, repair the transmission as necessary. Refer to Torque Converter Clutch (TCC) Diagnosis .
Go to Step 25
24
Replace the ignition control module. Refer to Ignition Control Module Replacement .
Is the action complete?
Go to Step 25
25
1. Review and record Freeze Frame data
2. Clear DTCs.
Go to Step 2
System OK
Document ID# 207566
Old Apr 21, 2010 | 11:40 PM
^ What in the bloody hell was all that?
PO300 means a random misfire. PO306 (her code) pinpoints the misfire to cylinder #6.
Old Apr 22, 2010 | 05:52 AM
September 2010 ROTM
There's no way in hell I'm reading all of that. I wanted someone's opinion based on their experience/knowledge...not a textbook explanation. And my code is P0306, I have my own diagnostic scanner, I know what code it's throwing.
Old Apr 22, 2010 | 06:10 AM
September 2010 ROTM
I talked to my bf about everything. We're gonna start with the spark plugs and wires and then if that doesn't work, look into the injector and lifter. I'm hoping it's just a bad wire or something, but with my luck, it's not that simple. I decided too that over the winter (if I can afford it) I'm going to have an 'engine refresher' done. Replacing all the gaskets and bearings and whatever else that might be in there. So hopefully the problem will be solved then if anything.
Old Apr 22, 2010 | 12:04 PM
As 69 said move the coil to a different position and see if the error follows the coil or stays with the cylinder. You could even move the injector and see if the issue follows that. Just be sure to try one thing at a time . Coil failure is pretty common. If it does not follow either you could have a problem with the modual.
Old Apr 22, 2010 | 12:20 PM
September 2010 ROTM
If it was the coil though, wouldn't there be a code for both cylinders?
Old Apr 22, 2010 | 06:24 PM
MusicMan's Avatar
The Jazz Man
Not necessarily. Sometimes that is the case, but sometimes not. Could also be the plug wire despite it looking good on the outside.
