Random wire set
Old Oct 22, 2010 | 08:25 PM
JordanN's Avatar
Default Random wire set
I have my fan on a manual switch. I was driving and it started sparking causing part of my dash to catch on fire. ( Bummer ) and it melted the wires from the switch ALL the way to the battery. After I got it home I came across this heavy gauge wire set that I have no idea what it goes to....
So if you have any ideas at all, please help.
Its a 95 3.4L
Jordan
Old Oct 22, 2010 | 08:56 PM
BasicConcepts's Avatar
Technical User
that came from under the dash???
Old Oct 22, 2010 | 09:13 PM
JordanN's Avatar
Yah, its actually not a wires but hollow tubes.
Old Oct 22, 2010 | 09:44 PM
osduck5's Avatar
Do those possibly plug on to the heater motor? That is the only thing I can think of under the dash that could demand a wire that big or possible someone left some wires under there from a stero/amp that was removed? Hey, they make fuses to prevent that kind of stuff!
Old Oct 22, 2010 | 10:04 PM
JordanN's Avatar
Learn by our mistakes, def going with a fuse this time.
Old Oct 23, 2010 | 02:44 AM
hollow tubes would be the vacuum hoses for the a/c, heater,defrost control. umm not sure were to get those. wrecking yard.
Old Oct 23, 2010 | 08:40 PM
JordanN's Avatar
They were clean cut before they melted, so I'm wandering if the Alarm installer cut them by mistake cause my heat hasn't worked for a while.
Thanks for the information you all!
Jordan
9434V6
Aug 19, 2011 08:52 AM
th3po1son
Apr 23, 2008 01:08 AM
twankieman91
Dec 19, 2007 06:46 AM
93CamaroGirl
May 2, 2007 03:16 AM
