Project hit a roadblock...need some help SOON
Old Jul 19, 2009 | 07:18 PM
WIspartan1026's Avatar
May 2013 ROTM
Default Project hit a roadblock...need some help SOON
Ok, so we're swapping a 3.4L from a 95 into the body from a 96 Z28. We got the motor/transmission out this weekend easy enough, and we were just about to put them into the Z body, but then we realized we had a slight problem. The bolt holes for the engine mounts aren't the same. We have the ones from the Z still, and I think we should be able to use one of them, but I don't know for sure. And the other one I doubt we'll be able to use at all.
I want to get this car on the road before I go back to school, so we can't afford any major delays. I NEED HELP SOON! thanks
Old Jul 20, 2009 | 07:43 AM
02StanGT's Avatar
thinking you have to change out the k member to the one of the engine you're installing
Old Jul 20, 2009 | 12:22 PM
May 2013 ROTM
i was afraid of that...is there anything simpler?
Old Jul 20, 2009 | 12:34 PM
evilkal's Avatar
This is correct. I did a swap for my buddy in HS. He got a 3.4 with a **** body and we were switching it into a 96 Z body and we had to swap out the K member. Drivetrain won't line up
Old Jul 20, 2009 | 03:08 PM
libertyforall1776's Avatar
Keep in mind the '96 never had a 3.4 option, it was 3.8 & 5.7 only...
Not what you want to hear, I know.
Old Jul 20, 2009 | 04:29 PM
May 2013 ROTM
good call. I completely forgot about that little detail.
Old Jul 20, 2009 | 09:42 PM
tripwire1124's Avatar
dont forget about the OBD II system. it switch in the 95's.
Old Jul 21, 2009 | 08:29 AM
May 2013 ROTM
forgive me if I sound stupid, but what is that? we are already switching the entire wiring harness.
One more thing: could we get away with welding the base of the engine mount to the k-member? My dad's a pretty good welder, so he could probably do it.
Old Jul 21, 2009 | 08:59 AM
On-Board-Diagnostics -- emissions & engine diagnostics related computer system. 95 Camaros has OBD I, 96 had OBD II, some 95s used and OBD II connector but is still an OBD I system.
Old Jul 21, 2009 | 11:09 AM
May 2013 ROTM
Where is that located?
(and how do you delete posts? you'll understand when you read the next one)
