A problem I think
Old Jun 2, 2006 | 02:38 AM
Bubonic's Avatar
Default A problem I think
I have a 95 3.4 liter V-6 Standard. Between 55 and 65 i hear a howl that seems to come from the exhaust? It gets quieter at higher speeds and I hear it wheather I am in 4th or 5th. Also I do a lot of driving and have to turn it off and on a lot. Would it be better for the AC to just leave it on when I turn the car off? I am a pizza driver (for the moment lol) I keep my ac on usualy or have to turn it on because where I live its hot and my fan doesnt turn on unless its on... my temp gauage has gotten a little above half way and i did not want it to go any further so I turned on the ac. Because with the ac on it stays at the quater mark or a little above on the temp guage.
Also what are the kind of things I should be looking for and paying attention to on this car?
Thanks
Old Jun 2, 2006 | 11:22 AM
94camaroLI's Avatar
Default RE: A problem I think
I had the same problem..I have 94 3.4L...My cuz checked my coolant sensor ( fan switch ) and that was the problem. It cost like $25 at your local car parts store. It's easy to install, just remember the car MUST be completely cold before you remove the old sensor. Then you can get a thermostat from hypertech ( Racing part stores usually carry them ) it will turn on your fan at a lower temp..(160 degree thermostat). Problem should cease.
Old Jun 3, 2006 | 04:49 AM
Bubonic's Avatar
cool thanks...
anyone know anything about the howling?
Old Jun 5, 2006 | 12:13 PM
94camaroLI's Avatar
check your serpentine belt.
Old Jun 8, 2006 | 10:26 PM
Bubonic's Avatar
I checked it and it looks ok. It has minor cracks here and there but nothing major.
Should I still change it? and do performance pulleys add anything on these cars?
Thanks
The howling sounds like its coming from my muffler or from that area.
Old Jun 9, 2006 | 01:37 PM
94camaroLI's Avatar
well...any cracks in your belt you should change it. As for perfomance pulley's if you live in a hot area I wouldn't do it because it draws power away from other accessories..like your a/c. If I were you take your car to a local muffler shop have them put it on a lift and see if you have a small crack or leak from your pipes. I had a 95 ford mustang and it was making the same sound...and when they put a blue light on my pipes they found a leak. once they welded it, problem gone.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
