problem can you help
Old May 4, 2009 | 11:22 AM
1999chevy's Avatar
Default problem can you help
hey i have a 99 3.8 liter camaro and i just put in a new stereo and there was an aftermarket stereo in there before but this time when i put it in when i try to roll down my windows my stereo just shuts down like i turned off the car and the windows dont work either and they dont work unless i dont start the car for a couple of weeks and ideas??
Old May 4, 2009 | 11:41 AM
02StanGT's Avatar
Did you have to rewire the harness for the new stereo? What you are describing sounds like a possible fault with the Body Control Module (BCM).
Old May 4, 2009 | 12:03 PM
1999chevy's Avatar
no it had an old harness that fit with the new sterieo wires and i hooked them up and tryed to play it and all that happen and i thought it was the alternater cause the plug with the one possative wire that pluges into it was hanging loose so i fixed that but that problem was still happening .how hard would it be to install a body control module?
Old May 4, 2009 | 12:51 PM
02StanGT's Avatar
I'm sorry, I mentioned the wrong module. It's the Retained Accesory Power (RAP) module.
Old May 4, 2009 | 01:56 PM
1999chevy's Avatar
well i replace the (bcm) first cause i found one for 45$ luckly thanks for your help
Old May 4, 2009 | 05:36 PM
02StanGT's Avatar
The BCM is for the lights and such.
Old May 4, 2009 | 06:06 PM
evilkal's Avatar
The RAP module is the one causing your problems. I had the same problem in my 99
Old May 4, 2009 | 07:27 PM
1999chevy's Avatar
ok ill check it ok thanks for the help and can u tell me where to find one
Old May 5, 2009 | 10:20 AM
1999chevy's Avatar
hey do you know where i can find the rap module in the car ?
Old May 5, 2009 | 11:10 AM
02StanGT's Avatar
http://shbox.com/1/express_down1.jpg
There is a pic I found. Below is a quote of what he said to test it.
If you want to pin down your problems to the RAP, unplug it and in the harness plug, jumper the brown wire to the dark blue and the pink. Turn on the key and see if all your stuff works. If it does, the RAP is to blame. If you want to dig inside it, you might be lucky like one guy I helped. He found a burned circuit tracing on the board inside. He soldered up the open tracing and it was back to working again.
