Posi rear end swap
Old Jul 10, 2010 | 10:06 PM
Chaotic94's Avatar
September 2011 ROTM
Default Posi rear end swap
I've looked around on here a little bit and didn't find anything in depth on a posi swap for 4th gen. How in depth is it? I'm not even sure what my factory gears are in my rear end. I was told they were 2.73 from one person and 3.23 from another. Can someone clear this up? Is there a way I can tell by looking at the VIN on my car or some other way?
Anyways...I'm looking for something along the lines of a posi rear end with 3.42 gears and disk brakes(I currently have drums). Where should I look to find one and will it bolt right in? Is there a better rear end for my car? Opinions, comments, and other options are greatly appreciated.
Old Jul 10, 2010 | 10:39 PM
Bobby95z28's Avatar
You probably have 3.23 but check your rpo codes in your glove box. 2.73 would be GU2 and 3.23 would be GU5.
Old Jul 10, 2010 | 10:41 PM
Chaotic94's Avatar
September 2011 ROTM
There are codes in the glove box? lol Which part of the "code" tells what I have?
Old Jul 10, 2010 | 10:44 PM
Bobby95z28's Avatar
Lol there should be. It's a list of 3 digit codes that tell you what options your car was built with.
There's a list of all of them
http://www.mafia-motorsports.com/for...rpo_codes.html
Old Jul 10, 2010 | 10:45 PM
Why do you need posi with a 3.4? I used to have a 94 and know the 3.4's "capabilities", which is why I ask.
Old Jul 10, 2010 | 10:47 PM
Chaotic94's Avatar
September 2011 ROTM
Just for the hell of it. I want the rear disks more than anything. My differential bearings are hitting the dust so I figured, "Hell put a posi with disks under the b**** lol". It costs just as much to do the bearings as it does to throw a whole rear end under it
Old Jul 10, 2010 | 10:49 PM
Ah, Ok, I c.
Old Jul 10, 2010 | 10:51 PM
Chaotic94's Avatar
September 2011 ROTM
And the liking for the 3.42 gears is I want the car to have a little more torque and acceleration more than top end. Should I be looking at something different to achieve that?
Old Jul 10, 2010 | 11:04 PM
That's not a bad all around gear for a 5 speed.
Here's some handy tranny info from my archived bookmarks: http://www.vibratesoftware.com/html_...nsmissions.htm
Old Jul 10, 2010 | 11:08 PM
Chaotic94's Avatar
September 2011 ROTM
sweet! thanks
