Plug missfire
Old Oct 10, 2008 | 03:17 PM
djschick88's Avatar
Default Plug missfire
I have a 2000 Camaro V6 and the ceck engine light came on so i pulled the code and it said spark plug missfire #1. I have changed the obvious spark plugs and the wires, what else should i check out?? Thanks
Old Oct 10, 2008 | 06:25 PM
Default RE: Plug missfire
The code just says that there is a misfire on cylinder #1. You just assumed it was a spark plug. Single cylinder misfire could be due to ignition problems (plugs, coil, wires), fuel injection problems (bad injector, bad injector wiring), mechanical problems affecting compression (bad valves, damaged valve train, blown gasket, etc..)
Old Oct 10, 2008 | 06:54 PM
hevymetalg's Avatar
my bet is one of the coil paks.
Old Oct 10, 2008 | 06:56 PM
hevymetalg's Avatar
switch the coil paks around and see if the mis follows
Old Oct 13, 2008 | 12:07 AM
djschick88's Avatar
Alright ill start switchin the coil around. Thanks...
Old Oct 13, 2008 | 04:48 PM
hevymetalg's Avatar
ORIGINAL: djschick88
no problem hope it helps,let me know what happends. o i got a new coil pack at autozone for $23 bucks.
Old Oct 15, 2008 | 07:30 PM
hevymetalg's Avatar
the spark plug wires connect to the coils if you have a v6 their should be3 coils and 6 plug wires connected to them ,2 wires per coil. the stock ones on my camaro are lable 123456 find them and theirs 2 nuts holding the icm which hold all 3 coils to it, you have to take the 2 nuts off and the wires comming off the back have a nut or screw holding the wires pluged in tothe icm. then you have to take any 2 coils off the icm and switch them around put it all back togather and run the car and see if the miss is at number 1 or if it moved. its not hard to do it just sound hard so lable the plug wires so not to mix them up then et in their and give it a shot later man.
Old Oct 16, 2008 | 05:13 PM
djschick88's Avatar
doing it right now...what exactly is the coil? is it the big black thing the plug wires go to or is it the little orange thing under it with the two metal prongs coming up?
Old Oct 16, 2008 | 05:30 PM
02StanGT's Avatar
It is what the plug wires hook onto.
maguilar496
Jun 4, 2012 08:28 AM
IdriveDSM08
Nov 23, 2011 06:36 AM
deadfast142
Mar 31, 2010 06:28 PM
Jay from Holland
Aug 6, 2008 02:42 PM
JerseyBoy9696
Jan 31, 2008 08:15 PM
