Performance Cams For the 3.4
I called Crane Today and gave them all the information about my car 94 3.4 v6 all that, and he suggested this cam POWERMAX 2030. what concerns me is the fact that it says it is made for 2.8-3.1L from 1980-1996. Will this cam work? I would imagine it would sense theoretically the 3.4 is basically a 3.1 stroked. But maybe he misunderstood when I said 3.4 maybe he thought i said 3.1, Any opinions? $209.00
Here's the Links....
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNum ber=254122&lvl=2&prt=5
UPDATE: Talked to SUMMIT and they advised me to go for Crane Compucam and Lifter Package for 169.00 RPM RANGE:1,500-4,500
http://store.summitracing.com/partdetail.asp?part=CRN%2D254122&N=700 4294908216 4294840048 4294819990 4294925232 4294924497 115&autoview=sku
Talked to SUMMIT again and was advised to go for the COMP CAMS HIGH ENERGY w/ Lifters for $204.00 Due to the fact that the rpm range is from 1,000 -5,000 RPM
http://store.summitracing.com/partdetail.asp?part=CCA%2DCL16%2D233%2D4&N=700 4294908216 4294840048 4294819990 4294925232 115&autoview=sku
2.4, 3.1, 3.4 are all basically the same and the cam will work fine in any of them, but make sure it is a flat lifter cam. The camaro 60 deg V6 block is 1 oil gallery short and cannot support roller lifters.
31, 34, 93, 94, aftermarket, cam, camaro, cams, camshaft, chevy, forum, increase, lifter, performance, proformence
