P0171 and P0174 fault code
Old Oct 1, 2011 | 07:35 PM
fillsgreat's Avatar
Default P0171 and P0174 fault code
I have a 2002 Camaro with a V6-Automatic.
I had a P0102, Mass Air Flow code first. I took the entire air intake assembly off, cleaned it, cleared the code.
MAF code came back, I used carb cleaner in the intake, replace the air filter, replaced the gas cap, cleared the code.
MAF code came back, I ordered a new Mass Air Flow Sensor from 2000-2004 CHEVY IMPALA New Aftermarket Mass Air Flow Sensor (MAF AFH50M-05 / AFH50M05 / 213-3428 / 2133428) DeluxeAutoMall.com - Chrome Auto Accessories & Replacement Car Parts
I installed and cleared the code.
Now I have P0171 and P0174 fault code, Fuel System Too Lean.
Has anyone had similar issues? Any suggestions?
Old Oct 1, 2011 | 08:23 PM
libertyforall1776's Avatar
There are a bunch of possibilities with this one. Are your O2 Sensors within spec for responsiveness? Cleaned your MAF wire with MAF Cleaner? Often replacing the sensor is not necessary, just cleaning the wire... If you have an oiled air filter, that can gum up the MAF wire, leading it to misread...
How many miles on the car and how many miles since the plugs/wires were replaced?
Old Oct 1, 2011 | 08:27 PM
Document ID# 770901
2002 Chevrolet Camaro
DTC P0171 or P0174
Circuit Description
The powertrain control module (PCM) controls the air/fuel metering system in order to provide the best possible combination of driveability, fuel economy and emission control. Fuel delivery is controlled differently during Open and Closed Loop. During Open Loop the PCM determines fuel delivery based on sensor signals, without oxygen sensor input. During Closed Loop the PCM adds oxygen sensor inputs to calculate Short and Long Term fuel trim, fuel delivery adjustments. If the oxygen sensors indicate a lean condition, fuel trim values will be above 0 percent . If the oxygen sensors (O2S) indicate a rich condition, fuel trim values will be below 0 percent. Short Term fuel trim values change rapidly in response to the heated oxygen sensor (HO2S) voltage signals. Long Term fuel trim makes coarse adjustments in order to maintain an air/fuel ratio of 14.7:1. If the PCM detects an excessively lean condition, this diagnostic trouble code (DTC) will set.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0107, P0108, P0121, P0122, P0123, P0130, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0201, P0202, P0203, P0204, P0205, P0206 P0300, P0401, P0403, P0404, P0404, P0405, P0410, P0440, P0442, P0446, P0506, P0507, P1404, or P1441 are not set.
The engine coolant temperature (ECT) is between 20-110°C (68-230°F).
The intake air temperature (IAT) is between 18-70°C (64-158°F).
The manifold absolute pressure (MAP) is between 15-105 kPa (2.1-15.2 psi).
The vehicle speed is less than 132 km/h (82 mph).
The engine speed is between 600-4,000 RPM.
The barometric pressure (BARO) is more than 70 kPa (10.1 psi).
The mass airflow (MAF) is between 5-150 g/s.
The fuel level is more than 10 percent.
Conditions for Setting the DTC
The average Long Term fuel trim value is above 20 percent.
All of the above conditions are present for 6 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
The system will go lean if an injector is not suppling enough fuel.
A lean condition could be present during high fuel demand due to a fuel pump that does not pump enough fuel.
Using a scan tool, review the Failure Records. If an intermittent condition is suspected, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
If conditions were not corrected, refer to Fuel System Diagnostics for a possible fuel problem.
If conditions were not corrected, a worn cam, worn intake or exhaust valves, or other the engine mechanical failures may be at fault.
Step
Action
Values
Yes
No
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
Important
If any DTCs are set, other than P0171, refer to those DTCs before continuing.
Install the scan tool.
Start and idle the engine at normal operating temperature in Closed Loop.
Record the Long Term fuel trim data.
Turn OFF the engine.
Turn ON the ignition, with the engine OFF.
Review the Freeze Frame/Failure Records, and record displayed data for this DTC.
Does the scan tool indicate that the Long Term fuel trim is greater than the specified value?
23%
Go to Step 3
Go to Diagnostic Aids
Operate the engine at idle.
Using the scan tool observe the HO2S parameters.
Does the scan tool indicate that the values are within the specified range and fluctuating?
200-800 mV
Go to Step 4
Go to Step 5
Visually and physically inspect the following items:
Vacuum hoses for splits, kinks, and proper connections--Refer to Emission Hose Routing Diagram .
Ensure that the vehicle has sufficient fuel in tank. If fuel pressure is too low this DTC may set--Refer to Fuel System Diagnosis .
Fuel contamination--Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
Did you find and correct the condition?
Go to Step 7
Go to Step 6
Check the HO2S for proper installation.
Check to ensure electrical connectors and wires are secured and not contacting the exhaust system.
Check for a short between the signal circuit and the low reference circuit.
Go to Step 7
Go to Fuel System Diagnosis
Check for missing, loose, or leaking exhaust components, forward of the HO2S.
Check for vacuum leaks at the intake manifold, throttle body and injector O-rings.
Check the air induction system and air intake ducts for leaks.
Check the secondary air injection (AIR) system for leaks, improper air delivery, shut off valve not closing.
Check crankcase ventilation system for leaks--Refer to Crankcase Ventilation System Inspection/Diagnosis in Engine Mechanical.
Go to Step 7
Go to Symptoms - Engine Mechanical
Important
After repairs, use scan tool Fuel Trim Reset function in order to reset the Long Term Fuel.
Use the scan tool in order to clear the DTCs.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 8
Go to Step 2
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Document ID# 770901
Old Oct 8, 2011 | 11:50 AM
fillsgreat's Avatar
Car has 96,083, wires and plugs replaced at 94,883.
How do I check the )2 Sensors??
Cleaned the MAF wires and AIT wires today and test drove, SIS light came on in 9.1 miles, same codes.
Old Oct 8, 2011 | 12:12 PM
fillsgreat's Avatar
OK, here is the freeze frame data...
DTC = P0174
Fuel Sys 1 = CL
Fuel Sys 2 = CL
Load PCT (%) = 2.0
ETC (F) = 198
SHRT FT1 (%) = 19.5
LONG FT1 (%) = 19.5
SHRT FT2 (%) = 19.5
LONG FT2 (%) = 19.5
MAP (in Hg) = 7.7
RPM (min) = 1040
VSS(mph) = 42
MAF (lb/min) = .487
TP(%) = 5.9
Where do I go from here? I cannot find any loose or bad hoses and I cleaned the MAF and AIT wires...
What do you think>
Old Oct 8, 2011 | 12:19 PM
fillsgreat's Avatar
DTC = P0174
Fuel Sys 1 = CL
Fuel Sys 2 = CL
Load PCT (%) = 2.0
ETC (F) = 198
SHRT FT1 (%) = 19.5
LONG FT1 (%) = 19.5
SHRT FT2 (%) = 19.5
LONG FT2 (%) = 19.5
MAP (in Hg) = 7.7
RPM (min) = 1040
VSS(mph) = 42
MAF (lb/min) = .487
TP(%) = 5.9
What do you think>
I just went and clarified/checked the Freeze Frame data,
MAP (kpa) = 26
So this would indicate I DO NOT have an intake manifold leak, right?
Old Oct 8, 2011 | 04:11 PM
Being that you have a lean condition, you may want to check the fuel pressure.
Old Oct 8, 2011 | 08:56 PM
Lightbulb
I am certain you have not gone through much of the long troubleshooting list I posted. You can lead a horse to water...
rdominy
Aug 9, 2014 10:24 PM
leelo
Sep 7, 2010 06:35 PM
blayman67
Feb 26, 2010 09:49 AM
CastleRockCamaro
Dec 15, 2009 02:01 AM
dough74
Nov 14, 2009 04:44 PM
