Overheating Problems
Old Jan 31, 2011 | 05:29 PM
you may have blown the head gasket when it overheated. if nothing else take the two heater hoses lose at the firewall and hook em together with a connector and a couple clamps or plug em. if your issue goes away, after filling and bleeding the cooling system then you know its the heater core.
Old Jan 31, 2011 | 07:54 PM
mrfreez's Avatar
How's the oil level? Is it milky? Do you see and fluid around the head gasket and lower intake? Do you get heat out of your car?
Old Jan 31, 2011 | 08:46 PM
AustinAckley's Avatar
Heat worked for about 10 minutes after we changed the thermostat; had not worked before then.
We're getting bombarded by this ice storm, so I'll have to check oil and those leaks later this week.
Also, engine sounds like a damn lawnmower, and is idling around 1500
Old Jan 31, 2011 | 08:58 PM
well id say you got something more than a bad heater core. 3.4 does not take kindly to overheating. like freeze said look for coolant in the oil or leakage around the head to block area.
Old Jan 31, 2011 | 09:38 PM
3800camaro's Avatar
Originally Posted by AustinAckley
Also, when it gets upto temp, steam starts coming out near the radiator cap as well.
could be a pin hole in your rad. Had the same problem with my car steaming out around the rad cap and it turned out to be a pin hole.
jdubs1813
Jun 28, 2009 09:07 PM
Robuilt
Apr 2, 2009 07:45 AM
Camaro_dudeZ28
Oct 31, 2007 09:48 AM
z28pete
Jun 15, 2007 07:49 PM
smokey
Jul 2, 2006 02:14 AM
