Overheating?!?!?! Help PLZ
Old 09-15-2008 | 11:05 PM
JaySan's Avatar
Default Overheating?!?!?! Help PLZ
Ok so I drive my car like 10 minutes and the temp guage gets to like 250 degress. On top of that my heater doesn't work. Any help is appreciated
Old 09-16-2008 | 10:33 AM
JaySan's Avatar
Default RE: Overheating?!?!?! Help PLZ
Its weird because the heater worked fine earlier that day. My car was low on cooland to I added Half water and half anti-freeze
Old 09-16-2008 | 07:15 PM
DeZ's Avatar
DeZ
check to see if the water hoses is busted open, thermostat could be leaking. radiator.
dont crack the head, they get pricey after awhile.
Old 09-16-2008 | 09:16 PM
02StanGT's Avatar
I would flush the coolant with some Prestone flush. Same thing happened to my girlfriend, and then to me when driving. I believe that with that little coolant, some flashes to steam. Steam in pipes doesn't transfer heat as well as liquid water. That's why I believe you can't feel the heat anymore. I flushed it first, somewhat helped. Then I replaced the water pump (after finding area of leak), then the tensioner assembly (because I broke it), but whatwas leaking was a little plastic elbow that goes fromunder the intake manifold neck to the tensioner. No more overheating. 3.8 or 3.4?
Old 09-21-2008 | 07:35 PM
xCx777's Avatar
Mine has been overheating latly... It did it the first time a few weeks ago.. it needed a new fitting on the hose... it started doing it again this past week, I replaced the thermostat in it... it seems to be running fine now.... check those two things
southw2
67-69 V8 Tech
06-12-2011 10:02 AM
greenmachine96
03-18-2011 12:29 PM
boxeranders
06-25-2009 01:05 AM
g.pelka
01-31-2008 07:00 PM
ChevCam87
82-92 V8 Tech
01-11-2008 11:46 AM
Quick Reply: Overheating?!?!?! Help PLZ
