overheating 3.4, something blocked?
Old Jan 5, 2008 | 03:14 PM
Gerland's Avatar
Default overheating 3.4, something blocked?
Howdy Camaro buddies,
I just changed my water pump as i knew i'd have do in a very close future due to a leak. It started overheating right before i changed it. Now that the new one is on is still overheat and does so pretty bad.
I am wondering if something is blocking the fluid to get to the engine as my level of fluid is high. when i opened my cap i noticed what looked like babypuke litteraly on it. Any ideas? would flushing eveything be the solution?
On top of it my coil is leaking under the passegenr's side at the height of the glovebox i believe.
Thanx guys, from a returning camaro fan!
G.
Old Jan 5, 2008 | 03:49 PM
GMDCAMARO's Avatar
Default RE: overheating 3.4, something blocked?
Ya i flushed mine. It had like chocolate pudding in it. Its was gross. But it helped alot. I ran the Prestone stuff, and then put in all new coolant. Its always worth a try
Old Jan 5, 2008 | 05:13 PM
Gerland's Avatar
was it overheating too?
Thanx man.
Gerland.
R_A_1978
Nov 19, 2012 09:47 AM
southw2
67-69 V8 Tech
Jun 12, 2011 10:02 AM
greenmachine96
Mar 18, 2011 12:29 PM
billgatesceo
Jun 29, 2009 11:26 AM
martian
Jan 8, 2007 07:10 PM
