Overdrive
When I shift into overdrive, it seems to make the RPMs jump about 300 then go to lower RPMs. Is this normal? In my brothers LT1, his just drops when he shifts into Overdrive.
3.4L
3.4L
I have this exact problem. In OD my rpms seem a little too highwhen im cruising. Then if I give it some gas it drops about 500rpms like the converter finally locks up. Also when it's cold, it takes a few seconds to go into R or D. When it's already warm it goes right into gear. I changed fluid and filter. No change. This a bad converter?
93. 3.4l auto
93. 3.4l auto
