Oldest question ever, Mods.
Old Jan 16, 2008 | 06:06 PM
Ronman's Avatar
Default Oldest question ever, Mods.
So I have a 99 v6 camaro and I just put on a flowmaster exhaust system and I was wonderin what some good ways to add some Hp would be. Any help would be appreciated and I'm lookin to spend around $500. Thanks.
Also, my car is hugger orange and I know its pretty rare or so I've heard, and I bought some 35th anniversary stripes to put on it, think it would look decent even without the hood scoop?
Old Jan 16, 2008 | 09:19 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default RE: Oldest question ever, Mods.
your new so i wont come down on you.....but please in the future use the search function.....but as far as mods go exaught is a good start also hit
cold air intake
Aluminumdrive shaft
headers
removal of cat or replacment with highflow cat
Old Jan 17, 2008 | 06:58 AM
02StanGT's Avatar
$500 won't get you a whole lot, especially if you don't do your own work...
Old Jan 17, 2008 | 05:55 PM
6v49der's Avatar
assuming you do your own work you are limited to one of bignic's suggestions on a 500$ budget. i guess since you already have a catback, start with a cai now, then headers, and start workin your way inside the engine after that....
Old Jan 17, 2008 | 10:41 PM
Ronman's Avatar
I was reading somw of the other post about cai and there were lots of complaints about it falling off. What could I do to prevent that?
Old Jan 18, 2008 | 09:58 AM
02StanGT's Avatar
Never heard ofone falling off. Just make sure it's hooked up right with the clamps tight.
Old Jan 18, 2008 | 11:34 AM
aleksandr's Avatar
You don't need a CAI for the '99. The '97 and older models had a crappy intake, but the '98+ stock intakes are as good as aftermarket. Only difference is that the aftermarket airlids don't have the little baffles inside of them like the stock ones do, but you can get rid of those yourself by cutting them out with a dremil tool and then sanding it down.
Headers would be a goodinvestment when it comes to power. You could get some good ones for under $300. Also would be fairly cheap to get the aluminum driveshaft (I've seen it for $150). That wouldn't give you too much of an improvement, but it will lower the rotational mass and possibly add up to 5 whp.
Old Jan 18, 2008 | 12:29 PM
Ronman's Avatar
Thanks for all the help guys, it's greatly appreciated.
NEVERLETITDIE
Nov 3, 2009 10:07 AM
96z2869
Jul 24, 2009 10:11 AM
