Oil Sensors Question
Old Jan 30, 2010 | 08:07 AM
Hotrod688's Avatar
Default Oil Sensors Question
94 3.4 v6 what does the oil pressure sensor and the oil level sensor do to the car when they go bad or don't work right?
Old Jan 30, 2010 | 08:26 AM
osduck5's Avatar
Your oil pressure on the dash will either peg the needle high or it will not register the proper oil pressure. Oil level sensor, I think, will energize a check oil level light on the dash and on some engines will actually shut them down, not sure on the 3.4.
Old Jan 30, 2010 | 09:25 AM
so do u have issues or did u just want to know what if?
Old Jan 30, 2010 | 09:59 AM
JordanT's Avatar
On this subject, does anyone know where I can get a connector for the oil level sensor?
Old Jan 30, 2010 | 10:58 AM
Hotrod688's Avatar
It goes back to this problem car runs for about 5 or 10 seconds and stop running
https://camaroforums.com/forum/showt...678#post298678 was wondering if these sensors would cause this problem.
Old Jan 30, 2010 | 12:13 PM
if its not showing oil pressure the computer will turn the fuel pump and or injectors off. have u replaced the sending unit. there should be two one for the oil pressure sensor and one for the oil pressure gage. sensor one is for the computer and should be down there by the oil filter. thats the one that should be giving u problems if thats what it is. could be the fuel pump itself.
Old Jan 30, 2010 | 07:51 PM
osduck5's Avatar
Go to a bone yard and find a vehicle that still has it hanging in the engine compartment. That is where I got one, then spliced it into the wiring harness, soidered and heat scrinked the splice.
Old Jan 31, 2010 | 11:38 AM
raysean22589's Avatar
No Need for the boneyard go to autozone the have the sensors its about 16$ for the oil pressure sensor easy as **** to change to its located right were the oil filter goes in just slid the boot off there are 2 differnt kinds one with a ground and without take it off and bring it there o and make sure you drain the oil be cause it will **** out all over the headers if you dont .
DDRDiesel
Jun 13, 2014 02:47 PM
dmoneey05
Feb 26, 2012 11:03 AM
goldylocks
Aug 7, 2011 04:39 AM
critt86
Jul 5, 2010 07:00 PM
Connerveritas
Dec 31, 2006 09:20 PM
