help me please
Old Jan 31, 2010 | 11:37 AM
garrongg25's Avatar
Default help me please
i have a 99 camaro with a 3.8 i tried to pull it through the top. i couldnt get the oil pan to clear the subframe. How do i do this.
Old Jan 31, 2010 | 12:31 PM
libertyforall1776's Avatar
The oil pan is removable...
Old Jan 31, 2010 | 12:39 PM
tripwire1124's Avatar
if you gotta lift to pull form the top then you can also pull the body off the engine. What you should do is get the lift and a rope or chain and put it in the engine compartment and drop the engine on a dolly and lift the body off and slide the engine out from undermneath.....or you can just take off the oil pan.
Old Jan 31, 2010 | 12:50 PM
could take the trans crossmember out and drop the rear of the trany. did u take the intake manifold off. that would help also.
