oil question
Old Oct 27, 2008 | 05:59 PM
tmangum's Avatar
Default oil question
my oil pressure seems to drop during idle. for example, when i am at a stop light my oil pressure drops, but then when i shift and start driving, my oil pressure goes normal again. it will also happen if i go into neutral and coast. i have had an oil change since this problem and it still seems to happen.. thanks in advance.
Old Oct 27, 2008 | 06:16 PM
02StanGT's Avatar
Default RE: oil question
Oil pump speed varies with engine speed. This means oil pressure will vary with engine speed.
Old Oct 27, 2008 | 06:28 PM
tmangum's Avatar
oh i see. well it used to not happen before i got the 1st oil change. so i just wasnt sure if there was a problem or not.. thanks for your help. also though, I have been getting reg oil changes with real oil and then by mistake, i went to a quaker state.. dumb me not knowing they would put synthetic in it.. would that have anything to do with it?
Old Oct 27, 2008 | 06:33 PM
02StanGT's Avatar
I doubt it. It has done that with both Camaros I have had.
Old Oct 27, 2008 | 09:43 PM
RSSteve's Avatar
Its normal, all vehicles do it. As previously stated oil pump speed varies with engine speed. Don't worry about it.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
