oil pressure
Yes it is!
Not all Fram filters are garbage just the ones in the orange boxes. The Tough Guard (grey) are ranked #2 filter behind the Mobil 1.
Massey
You're right! My bad! I had both sensors break on me at once. The oil pressure sensor os where you said, just above the oil filter.
Well my coolant leak is fixed and now the oil pressure seems to be high. I changed the oil as usual but this time I used a fram tough guard filter (silver) instead of the regular orange fram that I get. The pressure goes to about the second line from the top and down to about half a idle. Could the filter cause a spike in the pressure? I use castrol high milage 10w/30 oil. Thanks........1SG
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
