oil pressure
oil pressure
hello when i start the carit has 60 ilbs oil pressure and when i run it hard for a lil the pressure drops to 20 ilbs i dont think this is normal.if this is a problem can someone turn me to the right direction to fix this problem 1994 camaro 3.4l auto.
Is the 20 lbs. at idle when the engine is up to running temp? If so, that's pretty much in the "normal and acceptable" range for an older car. But if it drops down into the danger zone, you could have excessive bearing wear, or the sending unit could even be bad.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
