Oil gauge on cluster moves (idle)
Old Sep 4, 2008 | 10:37 PM
Y2KCamaro's Avatar
Default Oil gauge on cluster moves (idle)
I have a 2000 Camaro V6 3.8L and the oil pressure gauge needle is a bit over the mid-mark on highway. But is below the mid-mark in city streets. But the engine has a bit of a kick to it (very very minor misfire, may be a bad cat P0420).
But on idle, the oil pressure gauge needle then moves from both positions (slightly below mid to slightly over mid) but no where near the dangerous red.
What is making it move like that? It's never done that but could this be related to the P0420 trouble code? Thanks!
Old Sep 5, 2008 | 12:15 PM
ElementSkater's Avatar
Default RE: Oil gauge on cluster moves (idle)
well you could have a leak causing your loss in pressure
Old Sep 5, 2008 | 02:29 PM
02StanGT's Avatar
You saying it moves up and down when at idle? Do your rpms do the same thing at idle?
bd92rs
Apr 2, 2009 07:54 PM
brad87
Apr 26, 2008 10:37 PM
z28scorpio
Mar 14, 2007 10:27 AM
Stas
Feb 2, 2007 06:54 PM
