No Heat!
Old Oct 7, 2006 | 05:49 AM
94v6green's Avatar
Default No Heat!
94 3.4 and no heat. I can hear the door open/close when I turn the dial from cold to hot and back. The coolant level is good.
Old Oct 7, 2006 | 12:14 PM
Default RE: No Heat!
Check the hoses to the heater core, thay should be as hot as the radiator hoses. If they stay cool, the heater core may be clogged.
Old Oct 7, 2006 | 12:55 PM
siw234's Avatar
does it have climate control
Old Oct 9, 2006 | 12:48 AM
94v6green's Avatar
one heater hose is hot, the other is not....clogged heater core???
Old Oct 16, 2006 | 11:22 PM
94v6green's Avatar
Well I pulled the heater core out and shot water thru it and all sorts of junk poured out of it. So after taking the hoses loose and spraying water thru everything getting all the brown mucky stuff out of the lines, I flushed it and now.....I have heat!!!!
Old Oct 17, 2006 | 02:14 AM
That's the clue, both hoses should br hot if the core is clean. Being that you had gunk in the heater core, the radiator core is probably gunked up also. May be a good idea to flush it out also, and put in fresh antifreeze.
Old Oct 17, 2006 | 01:40 PM
shnormo's Avatar
That's also a good indication that that is rust. I wouldn't worry about it, but definately flush it out. Antifreez's color is the general guide line on the condition of rust inhibition.
c4maro
Feb 10, 2011 08:21 PM
92RS FTW
82-92 V8 Tech
14
Nov 26, 2010 07:37 AM
burning camaro
Nov 9, 2010 06:15 PM
sl1foru
Nov 10, 2007 10:16 AM
FullThrottleChick
Dec 6, 2005 09:59 AM
