New here and have a couple questions
Old Feb 8, 2007 | 12:08 PM
countryboy's Avatar
Default New here and have a couple questions
I have a 96 camaro with the Y87 package. First, what do these car's normally run at for temp. Mine is usually about half way between a fourth and the bottom. Im thinking i might need a new thermostat, but not sure. If so what kind should i get, 180? Also how can i get to the foglights and parking lights? My one fog light is burnt out and so is my parking light. I've heard that the K@N air filters let in dirt into your engine. Is this true, or are they a good filter if im looking at a cold air intake. Thanks
Old Feb 8, 2007 | 12:20 PM
bluovlh8er's Avatar
Default RE: New here and have a couple questions
i dont think a 70 dollar filter will let dirt into the eng. thermo should be at 180 or around stock that is.
Old Feb 8, 2007 | 02:12 PM
Get a stock thermostat 180 deg I believe.
Fog lights: Unbolt and remove entire housing from impact bar behind the fascia, and repalce bulb. Helps if u have small hands and are double jointed.
Parking lights: unbolt housing from fascia, remove sockets from housing & change bulb.
Enjoy!
Old Feb 8, 2007 | 02:27 PM
badinfluenceRS's Avatar
stock thermostat is 195*...I have a 180* in mine and it works out great
K&N Filters are great imo
Old Feb 8, 2007 | 03:03 PM
countryboy's Avatar
Ok thanks
Old Feb 8, 2007 | 04:41 PM
countryboy's Avatar
What should my temp gauge be running at? Mine sits half way between a fourth and the bottom. Thanks
chase0990
Jul 11, 2010 10:08 PM
toxicat
Apr 6, 2009 01:29 AM
rpope904
Jul 6, 2008 04:11 PM
whammer3024
Aug 20, 2007 10:03 AM
redt_top
Mar 14, 2007 11:00 PM
