Need Some Advice On An Engine Rebuild.
A short background.
Recently a group of friends and I came into possession of one of our friends old Camaros. It currently doesn't run and before he had an accident he was talking about rebuilding it for his son. We want to keep the car as close to his as possible (so no engine swaps) however some modifications aren't out of the question. I've been using Ftpp.net to gather a list of parts and would like some critique on if it's all compatible or if something will work better with something else etc... Money is not an obstacle. Car is a 94 3.4L.
Comp Cams Cam Set:
Lifters
Springs/Retainers
Locks
Stem Seals
Timing chain set
Intake/Exhaust 226/236 @.050
Lift with 1.5 Rocker .463/.474
Angle 112
Comp Cams Rocker Arm/Pushrod set:
1:6:1 or 1:52:1 (Not sure which we want/need)
Ross Racing Pistons:
Dish or Dome or Flat. (Not sure which will give us the best compression ratio)
Manley Connection Rods/Bearings:
Aluminum Ultralight
Exhaust: We decided with Magnaflow. We just aren't sure if we want to go with the 2 1/2" IP or 3" IP. I know I've seen some V6 cars with dual pipes that sound like damn ricers.
Induction: SLP CAI
Hypertech 160 degree thermo
Comp Cams Cam Set:
Lifters
Springs/Retainers
Locks
Stem Seals
Timing chain set
Angle 112
Aluminum Ultralight
Induction: SLP CAI
The best compression ratio will depend on what your goal is. I admire your desire to do this right but you are just working on one od the most limited V6 motors GM built. The problem is the flow thru the heads. Even with port and polish they do not flow well. You really want to make sure you research the Cam you install. If it is much higher lift then stock then it designed for higher RPMs. If your heads do not support the higher RPMs then you engine will have less HP with the bigger cam. There is not a lot of info on the RWD 3.4 there are a lot of parts out there designed for the FWD 3.4 and many will fit but like I said they will not help much. I have yet to read about anyone that has been happy with their modded Camaro 3.4. Most people would not be happy with 15 plus seconds in the 1/4.
The FWD version of the 3.4 uses a aluminum head that has decent flow and can be ported to have good flow.
when i was thinking about modding my 3.4 everything i was reading was saying to swap the heads and intake from a 3.5L (impala malibu G6 ect) you may wanna check out FullThrottleV6.com - 5th Gen V6 Camaro, Firebird, Grand Prix, Regal, Grand Am and Mustang Tech Forums thats where i got all my info
I have seen many people talk about the swap and I have even seen threads started where a lot of money was spent, but I have yet to see one finished with a dyno. If anyone knows of one could we please post a link.
It would be great if we could get a member to do it and document how easy or hard it is.
- K&N FIPK
- Accel 8.8mm Wires
- Accel U-Groove plugs
- Knife-edged and Polished TB
- 3" Catback Exhaust (Flowmaster 3 chamber...no series)
- 9.0:1 Compression Ratio
- Auburn Posi w/3.23:1 Gearing
- 140.2 rwhp / 183 rwtq (164 hp / 215 tq @ the crankshaft (motor) )
- K&N FIPK
- Accel 8.8mm Wires
- Cutout, fully open
- Gen III Aluminum heads, 1996 3100 intake manifold(s), 19# fuel injectors, 2000 3400 throttle body
- 9.6:1 Compression Ratio
- RKSport Headers
- Mac Torque Arm
- OEM Clutch
- 170.6 rwhp / 207.3 rwtq (200 hp / 243 tq @ the crankshaft (motor) )
- K&N FIPK
- MSD 8.5mm Wires
- RKSport Headers
- Mac Torque Arm
- Comp Cams custom grind (114/212/218)
- Spec Stage 3 Clutch
- Zexel-Torsen Posi w/3.23:1 Gearing
- 184 rwhp / 212 rwtq (216 hp / 250 tq @ the crankshaft (motor) )
Here's what I got off of FullthrottleV6 for a 3400/3100 head swap. I think I'm going to go the 3400 cylinder head route.
