Need Info. on Changing Intake Gaskets
Old 01-30-2011, 09:20 PM
Massey's Avatar
If it is comming from the center of the intake, kinda under the throttle body it is prolly the waterpump to manifold plastic elbow or the seam in between the upper and lower intake. If it is to the left or right of the intake near the heads then I would guess the lower intake to head. The elbow and lower intake to head are both very common leak points for this engine.
Massey
Old 01-31-2011, 07:14 AM
osduck5's Avatar
I think I would just replace the gasket set and L shaped elbows. Make sure the water pump weep hole is not leaking as well.
Old 01-31-2011, 01:07 PM
Massey's Avatar
^^ +1
Massey
Old 01-31-2011, 07:42 PM
mrfreez's Avatar
It sounds like the water pump since it's centered on the engine.
I hope these diagrams can help. Here's the procedure for changing the water pump and lower intake manifold:
Water pump:
http://www.gmtunerz.ca/docs/02waterpump.pdf
Lower intake:
www.gmtunerz.ca/docs/02lmanifold.pdf
zombiemoose
01-09-2015 08:10 AM
MS69 YENKO/4-SPEED
02-19-2013 11:14 AM
AlaJoe
11-11-2011 09:26 PM
ScottD
01-21-2010 11:21 PM
schwab7777
06-21-2009 12:09 AM
Quick Reply: Need Info. on Changing Intake Gaskets
