Need to change rear shocks also
RE: Need to change rear shocks also
if its a 98 like ur name, really easy just did mine.
got to pull carpet out the way in the back to get to the single bolt at top of shock, get it loose. then do the bolt at the bottom of the shock, thats it. i reinstalled mine by putting bottom bolt in first, getting it lined up, then cutting the wire keeping the shock compressed. then it slowly uncompressed, i just guided it throug the top hole, and bolted it up. like 1 hr tops
Dont forget about keeping the shock from spinning. You cant just loosen the nut from the top, the piston will spin on you if you try to loosen the nut. You need to either use vise grips or channel locks on the shock so its will stay stationary. If yo are really brave, you can cut the piston housing SLEEVE, NOT THE TUBE, then with a cutting wheel, cut the piston, remove the bushings, pull from top, then remove bottom bolt. I dont suggest this if your fairly new to spinning wrenches.
libertyforall1776
11-10-2007 03:04 PM
