Need "02" 3.8 EGR tube or how to make one
Old May 29, 2022 | 09:48 AM
02camaro3.8's Avatar
Default Need "02" 3.8 EGR tube or how to make one
I have a 2002 Camaro 3.8 and it has those stainless steel corrugated tubes, one from exhaust manifold to EGR, and one from EGR to the intake. I can’t find one anything on the internet, that will fit. If I cant buy, then I will have to make it, what kind of flare block should I use and would any stainless corrugated tube work?
Old May 30, 2022 | 06:54 AM
These do not go bad often. You should be able to find one at the junk yard. They have a connected system to other yards, If they don't have they should be able to get it. ITs the kind of part that you-pull it yards sell for next to nothing.
What happen to it that you could not reuse the existing flanges?
Old May 30, 2022 | 12:55 PM
The egr valve was disconnected when I purchased the car. I'm not sure why, both tubes were missing. I just figured it would be better hooked up than not. I've about decided to just leave it disconnected. I just don't like check engine light being on. I may have to just get it tuned
Old May 30, 2022 | 01:44 PM
Replacing the hose from a wrecking yard will be a lot less money than a tune.
Old May 31, 2022 | 01:15 PM
Also under normal driving the EGR can save you Gas.
Old May 31, 2022 | 10:01 PM
carid
Vendor Special Buys
Jan 18, 2021 07:24 AM
rsh3429
Apr 4, 2009 11:12 PM
brucehusker
Jun 25, 2008 07:49 AM
jbe123
Sep 7, 2007 12:40 AM
Saint_Ali
Aug 16, 2006 05:00 PM
