Making annoying noises
#22
Noises
OK everyone,
Now that we have settled the brake problem, I have one that may stump the best but I hope not!
I have a 2000 3.8 V6 Auto with 64,000 miles. Car runs great, great condition, no problem at all with anything EXCEPT:
I just starting hearing a resonance noise/hum but only in the passenger compartment, it is not coming from under the hood. It happens after a few minutes after I start the motor and whether the motor is hot or cold does not matter. I have ran 150 miles and 10 miles, same sound same symptoms.
The resonance noise/hum stops but ONLY when I am in gear and under acceleration, even slight acceleration but comes back when I slow down and sit at idle at a light. Once I hit the gas it goes away. Sometimes it is a low hum and other times it is very noticeable.
NOW, If I put the car in neutral and rev the motor the sound does NOT go away BUT once I put it in gear and accelerate its gone until I slow down again.
Fuel Pump?
Vacuum Leak on the tranny under the floor shift console?
Sending Unit in the tank?
I cannot tell where this is coming from? The only thing that has been a problem is the sending unit in the gas tank and does not give me an exact reading of fuel at the gauge.
Please give me some clues?
Fuel Pump?
#24
sounds like something in the trans. throw out bearing would be my first guess but u have a auto. could be torque converter. whens the last time u had the trans serviced?
#27
im confused who was talking about brake noises???? Gorn was talking about burning rubber haha
#28
exhaust
I recently fixed a rattle on my 96 3.8 after months of chasing it down. I put a dowel rod to my ear with the engine running. I could hear more noise when I put the dowel rod to the y-pipe than on the cluth housing or transmission. Try (with the engine off) to bang on the y-pipe with your hand to see if it rattles. Mine rattled all the time. Annoying goose chase for months. Finally took the y-pipe & cat off to see if anything fell out. Nothing fell out, but located my rattle. The long part (driver side) of the y-pipe is constructed of a pipe inside a pipe that had come loose. I drilled about five 1/8" holes across it and pop-rivited the two pipes together. Covered the rivets in exhaust patch putty before and after putting them in place. Doesn't rattle anymore and is about 300-400 bux less than y-pipe/cat replace.
#29
baran..is your cat gutted?oh,and nice jack on the post lol.other fellas with rattle a couple i have seen with a ghost rattle was just in front of the cat where pipe goes just above the transmission crossmember.pipe is really close to upper side of the crossmember(but that was on z-28 exhaust)and would occasionally rattle .you could tell it was coming from passenger side.more pronounced if you have a manual trans
#30
also dont hit your cat with a hammer too hard or it will bust up.i backed up close to a garage door and reved engine and heard and found lil pieces hitting the garage door when mine busted up.took my Z down a 10 mile washboard dirt road to go camping and it busted up the inside of my cat.and cracked my dash lol
