Major Door Problems?
Old 02-08-2010, 10:12 AM
1 pixel x 1 pixel is like a speck of dust. I think I sneezed the picture away!
Old 02-08-2010, 12:39 PM
Gmed1990's Avatar
I tried two different ways to put these pictures up. I know im not crazy I have done this before. ANYWAYS PLEASE let me know if the pics work and what a possible solution is. ALSO if this fails. The pics are in an album on my CF Page under DOOR. Thanks!
Attached Thumbnails Major Door Problems?-0206001320.jpg   Major Door Problems?-0206001321.jpg   Major Door Problems?-0206001321a.jpg
Old 02-08-2010, 02:20 PM
Now the pics work, that helps. For the regulator mounting bolts on the side of the door, it looks like a couple of the slotted holes are alright, but I would still use a large diameter washer to help span any weak area. On the one side hole that is hacked up, I would take a big washer and sand one side of it and the area on the door, then epoxy the washer onto the door. Do that after the regulator is adjusted and the other bolts are tightened down so that bolt will line up. Also do the same washer/epoxy fix with the top fractured holes.
StephenS
11-03-2012 10:11 AM
78maro
03-06-2011 09:18 PM
oneslowz28
06-26-2008 01:53 PM
patrick2269
02-21-2008 07:57 PM
6v49der
03-24-2007 10:17 PM
Quick Reply: Major Door Problems?
