MAF sensor testing
Old Jul 31, 2006 | 05:43 AM
sewerrat's Avatar
Default MAF sensor testing
Can you test the MAF sensor? Or does this require an expensive oscilloscope? Is it worth while to just replace it with a reman from NAPA? Are the remans decent quality?
Old Jul 31, 2006 | 07:15 PM
SickSickSick's Avatar
Default RE: MAF sensor testing
i'm not big on sensors but if the maf is bad you should have the SES light on. sick
Old Jul 31, 2006 | 07:53 PM
MadMikeZ28's Avatar
There are test you can do and if you get a Chiltons total car care manual there are flow charts that show you how to perform test.
Old Aug 1, 2006 | 01:31 AM
sewerrat's Avatar
Thanks Madmike, do you know if the flow chart will show values that I can test with a digital mult-meter or will I have to get an osc scope?
Sick thanks for your reply but the SES light momentarily comes on then goes off. I only read the MAF trouble code when I plugged in a reader.
fuhhuayt
May 5, 2011 01:04 PM
EagleRex
Jul 20, 2010 03:36 PM
draggo144
82-92 V8 Tech
Nov 15, 2008 06:42 PM
