lowering springs
What shocks are you running? Do not put lowering springs on stock shocks.
Ya it not that hard to do. If undoing the shocks doesn't drop it enough you'll have to unbolt the pan hard bar. So that'll be 3 bolts plus the 10 lug nuts. Not to bad. Lol.
Better find out what you have before you start this job -- chances are, your shocks are NOT going to control your lowering springs well, and you will not be happy with the ride. Which also means premature shock wear.
I would not lower the Camaro without Koni SAs, and in that case I'd go with Strano's lowering springs...
