low fuel pressure
Old Nov 30, 2009 | 05:21 PM
libertyforall1776's Avatar
Update: Guess I should have read the entire thread first... ;-)
Which codes do you get?
This should help:
Document ID# 348585
1999 Chevrolet/Geo Camaro
Fuel System Pressure Test
Circuit Description
When the ignition switch is turned ON, the Powertrain Control Module (PCM) will turn ON the in-tank fuel pump. The in-tank fuel pump will remain ON as long as the engine is cranking or running and the PCM is receiving reference pulses. If there are no reference pulses, the PCM will turn the in-tank fuel pump OFF 2 seconds after the ignition switch is turned ON or 2 seconds after the engine stops running. The in-tank fuel pump is an electric pump within an integral reservoir. The in-tank fuel pump supplies fuel through the fuel feed pipe, and in-line fuel filter to the fuel rail assembly. The fuel pump is designed to provide fuel at a pressure above the pressure needed by the fuel injectors. A fuel pressure regulator, attached to the Fuel Rail, keeps the fuel available to the fuel injectors at a regulated pressure. Unused fuel is returned to the fuel tank by a separate fuel return pipe. The fuel pressure gauge J 34730-1A and fuel pipe shut off adapters J 37287 are used for fuel system diagnosis.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
To relieve the fuel pressure, refer to Fuel Pressure Relief Procedure . With the ignition switch ON and the fuel pump running, the fuel pressure indicated by the fuel pressure gauge should read 333-376 kPa (48-55 psi). The spring pressure inside the fuel pressure regulator controls this pressure.
A fuel system that drops more than 5 psi in 10 minutes has a leak in one or more of the following areas:
The fuel pump check valve.
The fuel pump flex pipe.
The valve or valve seat within the fuel pressure regulator.
The fuel injector(s).
Fuel pressure that drops-off during acceleration, cruise, or hard cornering may cause a lean condition. A lean condition can cause a loss of power, surging, or misfire. You can diagnose a lean condition using a scan tool. If an extremely lean condition occurs, the oxygen sensors(s) will stop toggling. The oxygen sensor output voltage(s) will drop below 500 mV. The fuel injector width will increase.
Important
Make sure the fuel system is not operating in the Fuel Cut-Off Mode. This can cause false indications by the scan tool. Refer to Engine Scan Tool Data Definitions .
When the engine is at idle, the manifold pressure is low (high vacuum). This low pressure (high vacuum) is applied to the fuel pressure regulator diaphragm. The low pressure (high vacuum) offsets the pressure being applied to the fuel pressure regulator diaphragm by the spring inside the fuel pressure regulator. When this happens, the result is lower fuel pressure. The fuel pressure at idle will vary slightly as the barometric pressure changes, but the fuel pressure at idle should always be less than the fuel pressure noted in step 2 with the engine OFF.
A rich condition may result from the fuel pressure being above 376 kPa (55 psi). A rich condition may cause a DTC P0132 or a DTC P0172 to set. Driveability conditions associated with rich conditions can include hard starting followed by black smoke and a strong sulfur smell in the exhaust.
This test determines if the high fuel pressure is due to a restricted fuel return pipe or if the high fuel pressure is due to a faulty fuel pressure regulator.
A lean condition may result from the fuel pressure being below 333 kPa (48 psi). A lean condition may cause a DTC P0131 or a DTC P0171 to set. Driveability conditions associated with lean conditions can include hard starting (when the engine is cold), hesitation, poor driveability, lack of power, surging, and misfiring.
Restricting the fuel return pipe with the J 37287 Fuel Pipe Shut-Off Adapter causes the fuel pressure to rise above the regulated fuel pressure. Using a scan tool to pressurize the system, the fuel pressure should rise above 376 kPa (55 psi) as the valve on the Fuel Pipe Shut-Off Adapter connected to the fuel return pipe becomes partially closed.
Notice
Do not allow the fuel pressure to exceed 450 kPa (65 psi). Fuel pressure in excess of 450 kPa (65 psi) may damage the Fuel Pressure Regulator.
Check the spark plug associated with a particular fuel injector for fouling or saturation in order to determine if that particular fuel injector is leaking. If checking the spark plug associated with a particular fuel injector for fouling or saturation does not determine that a particular fuel injector is leaking, use the following procedure:
Remove the fuel rail, but leave the fuel pipes connected to the fuel rail. Refer to Fuel Rail Assembly Replacement .
Lift the fuel rail just enough to leave the fuel injector nozzles in the fuel injector ports.
Caution
In order to reduce the risk of fire and personal injury that may result from fuel spraying on the engine, verify that the fuel rail is positioned over the fuel injector ports. Also verify that the fuel injector retaining clips are intact.
Pressurize the fuel system by using a scan tool.
Visually and physically inspect the fuel injector nozzles for leaks.
Step
Action
Value(s)
Yes
No
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
Turn the ignition OFF.
Turn the air conditioning system OFF.
Caution
Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
Install the J 34730-1A fuel pressure gauge.
Place the bleed hose of the fuel pressure gauge into an approved gasoline container.
Turn the ignition ON.
Bleed the air out of the fuel pressure gauge into an approved gasoline container.
Turn the ignition OFF for 10 seconds.
Important:
The fuel pump will run for approximately 2 seconds. Cycle the ignition as necessary in order to achieve the highest possible fuel level
Observe the fuel pressure indicated by the fuel pressure gauge with the fuel pump running.
Is the fuel pressure within the specified limits?
Go to Step 3
Go to Step 12
Important
The fuel pressure may vary slightly when the fuel pump stops running, the fuel pressure should stabilize and remain constant.
Note the fuel pressure after the fuel pump stops running.
Does the fuel pressure drop more than the specified value in 10 minutes?
34 kPa (5 psi)
Go to Step 10
Go to Step 4
Relieve the fuel pressure to the first specified value.
Does the fuel pressure drop more than the second specified value in 10 minutes?
69 kPa (10 psi)
14 kPa (2 psi)
Go to Step 19
Go to Step 5
Do you suspect the fuel pressure of dropping-off during acceleration, cruise, or hard cornering?
Go to Step 6
Go to Step 8
Visually and physically inspect the following items for a restriction:
The in-line fuel filter.
The fuel feed pipe.
Did you find a restriction?
Go to Step 24
Go to Step 7
Remove the fuel sender assembly. Refer to Fuel Sender Assembly Replacement .
Visually and physically inspect the following items:
The fuel pump strainer for a restriction.
The fuel pump strainer for correct position, and installation on the fuel sender assembly
The fuel pump flex pipe for leaks.
Verify the fuel pump is the correct fuel pump for this vehicle.
Did you find a problem in any of these areas?
Go to Step 24
Go to Step 19
Important:
The fuel pump will run for approximately 2 seconds. Cycle the ignition as necessary in order to achieve the highest possible fuel pressure. Note this pressure.
Start the engine.
Allow the engine to idle at normal operating temperature.
Is the fuel pressure less than the noted fuel pressure by the amount specified?
21-69 kPa (3-10 psi)
Go to Symptoms
Go to Step 9
Disconnect the vacuum hose from the fuel pressure regulator.
With the engine idling, apply 12-14 inches of vacuum to the fuel pressure regulator.
Does the fuel pressure drop by the amount specified?
Go to Step 20
Go to Step 21
10
Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure .
Disconnect the fuel feed pipe and the fuel return pipe from the fuel rail. Refer to Quick Connect Fitting(s) Service (Metal Collar) .
Install the J 37287 fuel pipe shut-off adapters between the fuel feed pipe and the fuel return pipe and the fuel rail.
Notice
Open the valves on the Fuel Pipe Shut-Off Adapters.
Bleed the air out of the fuel pressure gauge.
Wait for the fuel pressure to build.
Close the valve in the fuel pipe shut-off adapter that is connected to the fuel feed pipe.
Does the fuel pressure remain constant?
Go to Step 19
Go to Step 11
11
Open the valve in the fuel pipe shut-off adapter that is connected to the fuel feed pipe.
Close the valve in the fuel pipe shut-off adapter that is connected to the fuel return pipe.
Go to Step 21
Go to Step 22
12
Is the fuel pressure above the specified limit?
376 kPa (55 psi)
Go to Step 13
Go to Step 15
13
Disconnect the fuel return pipe from the fuel rail. Refer to Quick Connect Fitting(s) Service (Metal Collar) .
Attach a length of flexible fuel hose to the fuel rail return outlet passage
Place the open end of the flexible hose into an approved gasoline container.
Turn the ignition OFF for approximately 10 seconds.
Observe the fuel pressure gauge with the fuel pump running.
Go to Step 23
Go to Step 14
14
Visually and physically inspect the fuel rail outlet passages for a restriction.
Go to Step 24
Go to Step 21
15
Is the fuel pressure above the specified value?
0 kPa (0 psi)
Go to Step 16
Go to Step 17
16
Install the J 37287 fuel pipe shut-off adapter between the fuel return pipe and the fuel rail.
Open the valve on the fuel pipe shut-off adapter.
Notice
Slowly close the valve in the Fuel Pipe Shut-Off Adapter that is connected to the fuel return pipe.
Does the fuel pressure rise above the specified value?
Go to Step 21
Go to Step 7
17
Perform Fuel System Electrical Test. Refer to Fuel Pump Electrical Circuit Diagnosis .
Did you find a problem with the fuel pump electrical circuit?
Go to Step 24
Go to Step 18
18
The in-line fuel filter for obstructions.
The fuel feed pipe for a restriction.
The fuel pump strainer for obstructions.
Important
It will be necessary to remove the fuel sender assembly in order to inspect the fuel pump strainer and the fuel pump flex pipe. Refer to Fuel Sender Assembly Replacement .
Go to Step 24
Go to Step 19
19
Replace the fuel sender assembly.
Is the action complete?
Go to Step 25
20
Locate and repair the loss of vacuum to the fuel pressure regulator.
Go to Step 25
21
Replace the fuel pressure regulator.
Go to Step 25
22
Locate and replace any leaking fuel injector(s).
Go to Step 25
23
Locate and correct the restriction in the fuel return pipe.
Go to Step 25
24
Repair the problem as necessary.
Go to Step 25
25
Caution
Important:
Go to Step 26
Go to Step 11
26
Important
34 kPa (5 psi)
Go to Step 10
System OK
Kendagenius
Feb 5, 2017 12:23 PM
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
doww301
Jun 15, 2010 05:11 PM
