Lethal or not?
Old Jan 19, 2010 | 06:37 PM
Interested1's Avatar
Default Lethal or not?
Hello everyone,
I was looking at a z28 2001 camaro today. The car looked beautiful inside and outside, except for its rear left side. The side was slightly skewed, the cover of the gas tank wouldn't close all the way as the trunk wouldn't either. When I opened the trunk and took the cloth mats out I saw a crack in the wheel arc, i.e. in the outdent that covers the rear left wheel and provides support for anything in the trunk.
Is that a part of the frame? Or can it be easily replaced?
Thank you,
The Interested1
Old Jan 19, 2010 | 10:10 PM
Jonny Dubyah's Avatar
v6 section..not for z28. but im sure it could just be welded nice and good..
Old Jan 20, 2010 | 03:08 PM
I guess I'm a little wrong. It wasn't a z28, it had a V6 engine thus it was a "regular" camaro. So it's body isn't fully made of metal then. Including the part that I've described. Is that correct?
Old Jan 20, 2010 | 03:24 PM
Stix80's Avatar
it should be plastic and i would keep looking around how much did the guy want for it
Old Jan 20, 2010 | 04:52 PM
If you remove the rear bumper cover, the crash bumper, and the hatch, then the rest of the back portion of the body is metal. That car has been hit pretty good on the left rear side, and it sounds like it's tweaked enough to where it's going to need to be straightened on a frame machine.
