Leaking Antifreeze
Old Mar 17, 2008 | 03:22 PM
ryanh_3's Avatar
Default Leaking Antifreeze
Ok here it I have been having this problem for about a month. My car is leaking antifreeze I have looked all over the engine to see if I could find the source with no luck. I have also searched all over this forum to see if I could find anyone with the same problem to no luck. The car is leaking antifreeze I can’t find the source it is a small leak the only place that I can find any trace of a leak is on the outlet hose from the water pump. I thought it might have been the water pump but I think it would have gone bad by now if that was the case anyone have any suggestions?
Old Mar 17, 2008 | 03:59 PM
02StanGT's Avatar
Default RE: Leaking Antifreeze
https://camaroforums.com/m_178693/tm.htm
Didn't even need the search function for this one. It was on page 1 of the 4th Gen.
Old Mar 17, 2008 | 06:40 PM
Ghost32's Avatar
I just had the same problem on mine a few weeks ago. It took me a minute to find it but is was a pin hole leak on one on the hose from the water pump to the heater core.
Old Mar 17, 2008 | 07:03 PM
ryanh_3's Avatar
does the t-housing have a paper gasket or does it have a rubber one?
Old Mar 17, 2008 | 07:10 PM
02StanGT's Avatar
I think the t-stat itself has a rubber gasket around it. If you want to put one on the housing, go for it.
Old Mar 22, 2008 | 02:06 PM
libertyforall1776's Avatar
Probably your water pump -- if weeping, it's your first sign of failure... I replaced mine myself on my '95 3.4L -- not too bad -- make sure you get a pully puller!
Old Mar 22, 2008 | 02:14 PM
02StanGT's Avatar
Why do you need a puller? It's just four bolts, and off the pulley comes...
Old Mar 25, 2008 | 11:34 AM
Labyrinth9's Avatar
you need to pull the pulley off of the power steering, but on the water pump itself it is 4 bolts. i did this too to my 3.4 it was simple, power braket has to come off adn be pushed aside btu its all easy bolts. noob may take 3-4 hours. good knowledge 2ish. and so forth. the pump wil have a weep hole and will puke the fluid out through, it will be obvious on the front of a 3.4 block.
make for dam sure that it is not gettign into the block through intake manifold gasket or head gasket. i had a freind whose pump was weeping and he replaced it and went on his way but the intake manifold gaskes was bad as well so he ignored it adn cased a fair ammount of damage to the engine.
Old Mar 25, 2008 | 03:06 PM
Jackpot4's Avatar
I have this problem now too, at first was my radiator and then the car overheated way too much one day and right after i replaced the radiator i find my timing cover is leaking and because of how hot it is down here its getting worse and i need to get it fixed hella soon.
Green94Maro
Aug 29, 2012 05:41 PM
crustyz
Aug 14, 2012 10:02 AM
TeamRetard
Jul 1, 2011 09:04 AM
sweeter
Apr 14, 2011 02:54 PM
STLDave
Jun 25, 2008 01:36 PM
