Leakage
Old 04-11-2010 | 03:55 PM
ROBCAMV6's Avatar
Default Leakage
I have a 93, and my wife was driving it and it started over heating. I noticed that the radiator and recovery tank were bone dry. I topped both off and started the engine so it could run through. I then noticed that it was just pouring out. Today I tried to find the problem, and its not the radiator or hoses like I thought. it is coming out from behind the center belt pulley. I think it might be the water pump, is that what it is?????
Old 04-11-2010 | 05:31 PM
Most common would be the water pump. There is also a plasic elbow that connects to the intake in the same area. If you feel around the back of the pulley and its wet then it is most likley it. If you want to 100% sure you and see the weep hole in the pump housing from under the car. It should be wet/stained.
cclovern
07-27-2012 08:10 AM
danni97
01-25-2010 07:08 PM
9camaro5
04-17-2009 09:53 AM
bprzybyl
04-20-2007 01:48 AM
85Camarodude
11-01-2005 05:50 PM
Quick Reply: Leakage
