Kill system HELP
Old Apr 9, 2008 | 07:08 PM
busyb's Avatar
Default Kill system HELP
93 Base camaro______Kill system will not let me crank my engine,.,. why will the Security lite notgo off is there anyway to bypass it,.,.,.,., PLEASE HELP EMail me if u want at moneyington@yahoo.com THANK'S ALOT
Old Apr 10, 2008 | 12:57 AM
TomS68's Avatar
Default RE: Kill system HELP
It sounds like what's happened is the theft deterrent system is not recognizing your key. Or you are trying to use a new key. Realize that you MUST use a key with the chip in it in order to start. If your computer has "forgotten" your key Or if you are trying to use a new key. I believe the procedure is to turn the key to the on position (dash lights on) but don't try to start it. Leave it in this position until the security light turns off. (Can be a long time) Then turn the key to the off position, not sure if you have to remove it or not but go ahead just for luck, Then advance the key to the on position again and sit until the security light turns off. Turn it off again. Turn it on again and wait. After you've completed the cycle three times the computer should recognize your new key and you should be able to turn over the engine. Make sure your lights are off as well as your fan and radio as this is a time consuming and battery consuming process. Good luck!
Thanks,
Tom
ifeelfreely
Jul 22, 2010 10:32 PM
isaac11
VS
Mar 5, 2009 01:56 PM
CamaroKid16
VS
20
Jun 11, 2007 01:55 PM
BigNic
VS
24
May 10, 2007 07:00 AM
69camaro1
Oct 11, 2006 03:59 PM
